扫一扫,分享给好友
嗨,
下载xilinx vivado时出现此错误 请更正错误并再次发送您的信息。 由于您的帐户导出合规性验证失败,我们无法满足您的要求。 以上来自于谷歌翻译 以下为原文 Hi, I am getting this error while downloading xilinx vivado Please correct the errors and send your information again. We cannot fulfill your request as your account has failed export compliance verification. |
2个回答
你好@ waqarahmed6095
请通过以下链接,希望这有助于: https://www.xilinx.com/support/answers/44043.html 问候 罗希特 RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi @waqarahmed6095 Please go through the below link, hope this helps: https://www.xilinx.com/support/answers/44043.html Regards Rohit Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
你好@ waqarahmed6095,
您是否检查过与出口合规性失败问题相关的答复记录? https://www.xilinx.com/support/answers/44043.html 如果您已检查了所有建议但由于“导出合规性警报”仍无法继续,则由于我们的出口合规性团队对您的个人资料进行了筛选,您可能无法生成许可证或下载Vivado 并被搁置。 在这种情况下,请发送电子邮件至Xilinx客户支持(websupport@xilinx.com),表明您的“出口合规性”问题,他们将代表您联系XilinxGlobal贸易合规团队,他们将能够筛选和验证您的个人资料以及是否 一切都很好,然后重新激活它,这样你就可以登录并下载所需的软件而不会出现问题。 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @waqarahmed6095, Have you checked this Answer Record in relation to Failed export compliance issue? https://www.xilinx.com/support/answers/44043.html If you have checked all of the suggestions and still are unable to proceed due to the "export compliance alert", there is a possibility that you are currently unable to generate a license or download Vivado due to your profile being screened by our export compliance team and placed on hold. In this case, please send an email to Xilinx Customer Support (websupport@xilinx.com) indicating your "export compliance" issue and they in turn will contact Xilinx Global Trade Compliance team on your behalf, who would be able to screen and verify your profile and if all is good, re-activate this then, so that you can then login and download the required software without issues. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2304 浏览 7 评论
2714 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2196 浏览 9 评论
3277 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2346 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
625浏览 1评论
1679浏览 1评论
185浏览 1评论
648浏览 0评论
1834浏览 0评论
GMT+8, 2024-9-18 11:16 , Processed in 1.746955 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
