电子发烧友论坛|
先生,我已将一个晶体管连接到另一个晶体管。
如何实现两个晶体管Vds = 3V和Ids = 60mA的偏置。 我使用了两个ATF54143晶体管,并在一个晶体管X2(如图所示)Vds = 3v(电压差为3伏,Ids = 60mA)下实现了偏置。 但是我无法在Vds和Ids = 60 mA时在X1晶体管(如图所示)上实现3伏电压的差异。 我按照Active_Feed_Example的例子连接了连接晶体管的有源反馈(如图所示)。 你能帮助我在两个晶体管上实现Vds = 3Volts和Ids = 60mA吗? Activ_FeedBack_Example.jpg13.7 KB 以上来自于谷歌翻译 以下为原文 Sir, I have connected the one transistor is feedback to the other. How to achieve the biasing for two transistors Vds = 3V and Ids=60mA. I have used the two ATF54143 transistors, and achieved the biasing at one transistor X2(shown in figure) Vds=3v (potential difference of 3 volts and Ids = 60mA). But I couldn't achieve the difference of voltage of 3 volts at X1 transistor (shown in figure) at Vds and Ids =60 mA. I have connected the active feed back of connection transistor as I followed the example of Active_Feed_Example(it is shown in the figure). Can you anybody help me to achieve the Vds=3Volts and Ids=60mA at the two transistors. 附件
4个回答
您错过了将Ic2电流接地的连接。
漏极/ RL连接看起来也不正确。 以上来自于谷歌翻译 以下为原文 You are missing the connection that would take the Ic2 current through to ground. The drain/RL connections don't look right either. |
先生,即使我们连接漏极/ RL电阻,也不能在X1的漏极和源极达到Vds = 3v的差异。有人帮助我在X1处获得Vds = 3v。 以上来自于谷歌翻译 以下为原文 sir, even if we connect drain/RL resistance also, am not able to achieve Vds=3v difference at drain and source at X1.someone plz help me to get the Vds=3v at X1. |
hu_wflllllllg21 发表于 2018-12-27 09:37 先生,有人可以帮助我解决这个困难 以上来自于谷歌翻译 以下为原文 Sir, Some one can help me to resolve this difficulty |
嗨nimbargi,ADS论坛是一个社区,旨在让您直接与世界各地的其他ADS用户进行交流,旨在提供一个询问和回答其他用户的问题,交换想法,分享使用技巧和窍门的地方 ADS。 ADS论坛不是联系Agilent EEsof技术支持的最佳或主要方式。 为了获得有关您的问题的帮助,我建议您直接联系Agilent EEsof支持,或访问ADS支持主页http://edocs.soco.agilent.com/display/support/ADS+Support+Home访问ADS支持和文档。 Joe Civello ADS产品经理 以上来自于谷歌翻译 以下为原文 Hi nimbargi, The ADS Discussion Forum is a community created to allow you to communicate directly with other ADS users around the world and is designed to be a place to ask and answer other users’ questions, exchange ideas, and share tips and tricks for using ADS. The ADS Discussion Forum is not the best or primary means to contact Agilent EEsof Technical Support. To get help with your issue, I suggest you contact Agilent EEsof support directly or access ADS Support and Documentation by visiting ADS Support Home http://edocs.soco.agilent.com/display/support/ADS+Support+Home. Joe Civello ADS Product Manager |
只有小组成员才能发言,加入小组>>
285 浏览 0 评论
1870 浏览 0 评论
2756 浏览 1 评论
2658 浏览 1 评论
2478 浏览 5 评论
1871浏览 0评论
434浏览 0评论
285浏览 0评论
/9
GMT+8, 2025-12-14 07:14 , Processed in 0.864390 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1959
