PWM配置如下:
/************************************************* Function: TIM1_Init() Description: pwm2输出 *************************************************/ void TIM1_Init_PWM2(uint16_t arr,uint16_t psc) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOE,ENABLE); //PE9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(GPIOE, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOE, GPIO_PinSource9, GPIO_AF_2); //TIM1channel RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); //定时器TIM1时钟使能 //TIM_DeInit(TIM1); //设置在下一个更新事件装入活动的自动重装载寄存器周期的值 TIM_TimeBaseStructure.TIM_Period=arr; //设置用来作为TIMx时钟频率出书的预分频值 TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置时钟分割 TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置计数模式 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; //初始化参数 TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //TIM1的channel TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; TIM_OCInitStructure.TIM_Pulse = 0x90; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High; TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset; TIM_OC1Init(TIM1, &TIM_OCInitStructure); //TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable); //TIM_ARRPreloadConfig(TIM1,ENABLE); TIM_Cmd(TIM1, ENABLE); //使能TIM1 TIM_CtrlPWMOutputs(TIM1, ENABLE); } PWM配置后,PE9输出无波形 |
7个回答
TIM_OCInitStructure.TIM_Pulse = 0x90; 这个arr如果小于0x90就没有输出了。 |
你的arr和psc是多少?时钟确定正常吗?
arc = 2000 psc = 1000;还是无法输出
你的TIM1_Init_PWM2(uint16_t arr,uint16_t psc)为什么要设入口参数,是为了在主函数开头初始化之外的地方调用吗?
配置有问题的
信心看看手册哦
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
636 浏览 1 评论
976 浏览 0 评论
858 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
4810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
3612 浏览 1 评论
/9
GMT+8, 2025-12-12 00:54 , Processed in 1.133995 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2523
