电子发烧友论坛|
当我从ST的站点编译示例代码时,我在项目目录中收到错误“无法访问文件:.Idea_Temp IDEABLD.BAT”。检查访问权限.....''
我尝试搜索IDEABLD.BAT,但在计算机上的任何地方都找不到它。我已经尝试重新安装COSMIC编译器,但仍然会收到此错误。有什么建议么? #宇宙编译器STM8L-ideabld 以上来自于谷歌翻译 以下为原文 When I go to compile the sample code from ST's site, I get the error ''Can't Access File: .Idea_TempIDEABLD.BAT in Project directory. Check access rights .....'' I tried searching for IDEABLD.BAT, and I can't find it anywhere on my computer. I've already tried reinstalling the COSMIC compiler, and still get this error. Any suggestions? #cosmic-compiler-stm8l-ideabld |
2个回答
为了跟进,我从来没有得到过如何使COSMIC IDE工作的解决方案。我最终安装了STVD(调用STM8 COSMIC编译器,BTW),这似乎工作正常。
以上来自于谷歌翻译 以下为原文 Just to follow up, I never did get a solution of how to make the COSMIC IDE work. I ended up installing STVD (which calls the STM8 COSMIC compiler, BTW) and that seems to work just fine. |
你好,
我们确实回复了您的电子邮件,建议问题可能来自安装“非标准”路径,因为我们没有反馈,我们认为问题已经关闭。 现在你有了一个可行的解决方案,所以我猜你会坚持下去,但是如果你想让IDEA工作,请直接与我们联系(如果你愿意,可以继续讨论)。 问候, 卢卡 以上来自于谷歌翻译 以下为原文 Hello, we did reply to your email suggesting that the problem probably comes from an installation with ''non-standard'' paths and since we had no feedback on that we assumed the issue was closed. Now you have a working solution so I guess you will just stick with it, but if you want to get IDEA working please contact us directly as you already did (or continue the discussion here if you prefer). Regards, Luca |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1472 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1524 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3674 浏览 1 评论
3864 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2483 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
752浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
684浏览 5评论
730浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
975浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
779浏览 5评论
/9
GMT+8, 2025-12-14 11:20 , Processed in 0.844266 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6238
