电子发烧友论坛|
我有一个32 MX795F512驱动7“TFT显示在16位的PMP模式-所有成功运行。然而,最近出现了一个问题(我想不出任何改变了),只要安装被允许休息大约10-15分钟,安装就开始了。如果我关机,然后尝试运行,我得到一个空白屏幕-屏幕甚至不清楚。我们认为热效应或电荷效应在这种情况下,但现在我感到困惑-我张贴这只是为了万一其他人遇到了一个温暖的启动问题,一个经验丰富的32 MX用户可能R。如果发生这种情况,那就检查一下!-或者我希望。振荡器每次都会开始。不幸的是,我只有原始的调试能力,当然,问题可能与TFT板(最常见的中国/易趣网品牌)有关。
以上来自于百度翻译 以下为原文 I have a 32MX795F512 driving 7" TFT display in 16bit PMP mode - all running successfully. However a problem has recently arisen (and I can't think of anything that's changed) where the setup will only start if it has been allowed to 'rest' for about 10-15 minutes. If I switch off and then try to run I get a blank screen - and the screen won't even clear. We think of heat effect or charge effect in such a case but right now I'm perplexed - I am posting this just in case anybody else has come across a wARM-start issue of this kind - a seasoned 32MX user might respond "if this happens then check that!" - or so I hope. The oscillator starts every time by the way. I have only primitive debug capability unfortunately and, of course, the problem could be with the TFT board (the most common China/Ebay brand). |
3个回答
HII将不适用于一个“经验丰富的PIC32 MX程序员”,但我已经与一个8位微控制器有同样的问题。我的情况是,我发现它是由于缺少BOR设置。解决了BOR的正确设置问题。
以上来自于百度翻译 以下为原文 Hi I would not apply as a "seasoned PIC32MX programmer", but I've already had that same problem with an 8 bit micro. I'm my case I found out that it was due lack of BOR settings. The case was that the residual power on the board took all that time to drop bellow the trip point of the reset circuitry of the micro. Solved enabling the BOR with a correct setting. HIH Best regards Jorge |
JorgeThanks提出这个明智的建议。我试着检查BOR标志是否被设置了,事实上,控制器正在运行除了TFT板之外的其他东西(LEDs ON和OFF),所以我开始认为这就是问题所在。我还确保在重新启动之前(包括在TFT板上),我把所有的电源线都放电了。结果是一样的。
以上来自于百度翻译 以下为原文 Jorge Thanks for this sensible suggestion. I tried checking whether the BOR flag was being set and it wasn't: in fact the controller is running stuff other than the TFT board (LEDs on and off) so I am starting to think that's where the problem is - I also made sure I discharged all power lines before re-booting (including on the TFT board) and the result was the same. |
确保你没有任何浮动的输入引脚。此外,如果你的PIC有JTAG,而你没有使用它,请确保它是禁用的。
以上来自于百度翻译 以下为原文 Make sure you don't have any floating input pins. Also, if your PIC has JTAG and you're not using it, make sure it is disabled. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:03 , Processed in 0.618952 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
10146
