电子发烧友论坛|
HI。
我们正在使用“34901A”卡来容量ch1~20,我们需要更多。 我们可以使用指定为DC VOLTAGE的当前通道的通道21和22吗? 0-10v任何信息将不胜感激。 我查看了卡和控制器上的规格,但我没有看到任何提及直流测量。 谢谢! 以上来自于谷歌翻译 以下为原文 HI. we are using "34901A" cards to capacity ch1~20 and we need a couple more. Can we use channel 21 and 22 designated as current channels for DC VOLTAGE ? 0-10v any information would be appreciated. I have looked over the specs on the card and controller but I don't see any mention of DC measurements. thanks! |
1个回答
不幸的是,这不起作用。
通道21和22具有旁路继电器,无论何时进行电流测量,它们都将Hi和Lo端子短接在一起。 (通道93和94 - 请参阅34970A / 72A用户指南第201页的34901A布局)。 这样做是因为您不希望任何时候打开当前路径。 因此,如果您将电压连接到这些通道Hi和Lo将短路在一起。 以上来自于谷歌翻译 以下为原文 Unfortunately this will not work. Channels 21 and 22 have bypass relays that short the Hi and Lo terminals together whenever current measurements are not being made. (channels 93 and 94 - See the 34901A layout on page 201 of the 34970A/72A User's Guide). This is done because you don't want the current path open at any time. So if you connected a voltage to these channels Hi and Lo would be shorted together. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 00:49 , Processed in 0.600160 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5579
