电子发烧友论坛扫一扫,分享给好友
我一直在使用Vivado 2015.4
今天早上我更新到2015.4.2 现在我收到以下消息: - [Common 17-345]找不到功能'Synthesis'和/或设备'xc7z045'的有效许可证。 请运行Vivado许可证管理器以获取有关确定哪些功能和设备已获得系统许可的帮助。解决方案:在Vivado许可证管理器中检查许可证的状态。 对于调试帮助,请搜索Xilinx支持“许可常见问题解答”。 我有一个节点锁定许可证,附带zc706开发套件,现在已经超过一年了。 它应该不适用于此次修订更新? 如果不是我如何恢复到版本2015.4 asit似乎没有通过网站提供 感谢您对此提供的任何帮助.. 院长 以上来自于谷歌翻译 以下为原文 I have been using Vivado 2015.4 This morning I updated to 2015.4.2 Now i get the following message :- [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z045'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". I have a node locked licence that came with a zc706 dev kit that is now more than one year old. should it not work with this minor revision update? If not how do i restore to version 2015.4 as it doesn't seem to be available via the website Thanks for any help that you can give on this.. Dean |
7个回答
@deanbruce,
如果您的问题已解决,请通过将适当的回复标记为解决方案来关闭此主题。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @deanbruce, If your issue is resolved, please close this thread by marking appropriate reply as solution. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).View solution in original post |
嗨@ deanbruce,
请在此处发布您的许可文件。 对于使用Vivado 2015.4.2,您需要版本限制为2016.02,而您需要2015.11作为使用Vivado 2015.4的版本限制。 有关详细信息,请参阅此AR:http://www.xilinx.com/support/answers/33770.html 从以下链接安装Vivado HLx:http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2015-4.html 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @deanbruce, Please post your license file here. For using Vivado 2015.4.2, you need version limit as 2016.02, while you need 2015.11 as version limit for using Vivado 2015.4. Refer this AR for details: http://www.xilinx.com/support/answers/33770.html Install Vivado HLx from this link: http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2015-4.html Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
你好
许可证限制为一年零一个月,还是版本号呢? 假设它已经过期,我该如何重新下载设计套件2015.4 谢谢 Xilinx.lic 10 KB 以上来自于谷歌翻译 以下为原文 Hi is the licence limited to one year and a month or is it the version number then? assuming it has expired, how can i re-download design suite 2015.4 thanks |
@deanbruce,
它由许可证中提到的版本限制决定(在您的情况下为2016.01,不允许您使用2015.4.2)。 使用此链接(http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2015-4.html)安装2015.4。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @deanbruce, It is decided by the version limit mentioned in the license(in your case 2016.01, which does not allow you to use 2015.4.2) . Use this link ( http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2015-4.html ) to install 2015.4 . Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
我错误地认为HLX下载是针对vivado HLS的,我还认为Web安装客户端是针对网络版的
哇! 谢谢 以上来自于谷歌翻译 以下为原文 I incorrectly assumed that the HLX download was for vivado HLS also i thought that the web install client was for the web edition doh ! Thanks |
@deanbruce,
如果您的问题已解决,请通过将适当的回复标记为解决方案来关闭此主题。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @deanbruce, If your issue is resolved, please close this thread by marking appropriate reply as solution. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
你不能奖励旧版本的工具。
你需要卸载并重新安装。 我建议您续订Vivado许可证并使用最新的Vivado 2016.2 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 you can't reward back old version of tool. you need to unstall and install again . I would recommend you to renew Vivado license and use latest which is Vivado 2016.2Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 06:26 , Processed in 0.639089 second(s), Total 53, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1575
