电子发烧友论坛|
你好,
正如我们所知,每个CPU可以在睡眠中独立于其他CPU的状态。如果两个内核处于不同的功率模式,那么这意味着相同的外设对不同的内核表现出不同的性能吗? 以上来自于百度翻译 以下为原文 Hi, As we know, each CPU can be in sleep independent of the state of the other CPU. If two cores are in different power modes, does that mean the same peripheral shows different performance towards different cores? |
2个回答
不,外围设备本身不显示不同的行为或性能取决于它们与之交互的核心。CPU的电源模式不影响外围设备的性能,只要系统处于活动模式(即CPU中的至少一个不是处于休眠功率模式)。即使当两个CPU处于休眠模式时,外围设备仍然保持活动,并对其配置/性能起作用。
也就是说,M4和M0+使用不同的接口(而不是基础设施)来与外围设备(MMIO寄存器接口)交互。M4使用快速基础设施和M0+(和其他总线主机,如DMA,加密)使用缓慢的基础设施,以连接到外设。为了便于多主接口,在设备中提供仲裁器(选择要与之交谈的主接口)和桥接器(同步时钟到周边时钟域)。因此,您可以观察到一些(读取的‘预期’)性能降低(取决于在任何给定时间的活动总线主控器的数量)。 让我知道如果这有帮助,或者如果你需要进一步澄清。 当做, Meenakshi Sundaram R 以上来自于百度翻译 以下为原文 No, the peripherals as such do not show different behavior or performance depending on the core they are interacting with. The CPU's power mode does not impact the peripheral's performance as long as the system is in Active mode (i.e. at least one of the CPU is not in DeepSleep power mode). Even when both the CPUs are in Sleep mode, the peripherals remain active and function to their configuration/performance. That said, M4 and M0+ use different interface (rather infrastructure) to interact with the peripherals (the MMIO register interface). M4 uses fast infrastructure and M0+ (and other bus masters like DMA, Crypto) use slow infrastructure for interfacing to the peripherals. In order to facilitate multiple master interface, arbiters (select the master interface to talk to) and bridges (sync's the clock to the peri clock domain) are provided in the device. Because of this you may observe some (read 'expected') performance reduction (depending on the number of active bus masters at any given time). Let me know if this helps or if you need further clarification. Regards, Meenakshi Sundaram R |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7367 浏览 0 评论
2486 浏览 1 评论
2178 浏览 1 评论
4045 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2089 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7869浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6431浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
760浏览 2评论
735浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8283浏览 2评论
/9
GMT+8, 2025-12-14 12:53 , Processed in 0.694182 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
510
