扫一扫,分享给好友
嗨,
我正在尝试为独立计算机重新分配vivado许可证文件。 当我进入许可网站时,修改按钮显示为灰色。 我已经使用激活后来的html链接导航到网站,并通过标准的Web访问进入。 请告诉我如何从旧的独立机器(不再存在)中停用许可证,以允许我使用我们购买的产品。 干杯 蒂姆 以上来自于谷歌翻译 以下为原文 Hi, I am trying to reallocate a vivado license file for a stand alone machine. When I go into the licensing website the modify button is greyed out. I have navigated to the website using both the activate later html link and by going in through standard web access. Please tell me how to deactivate a license form an old standalone machine (which no longer exists) to allow me to use our purchased products. cheers Tim |
5个回答
嗨@ hf4xinx,
你的意思是你想重新托管许可证吗? 你有没有在以前的任何时候重新托管它?谢谢,Nupur 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @hf4xinx, Do you mean you want to rehost a license? Have you rehosted it anytime earlier? Thanks, Nupur Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
要重新托管激活许可证,您需要先返回许可证。
成功返回许可证后,它将被添加回您的帐户,然后您需要为独立计算机重新生成许可证。以下AR具有返回基于激活的许可证的步骤。 http://www.xilinx.com/support/answers/60525.html 以上来自于谷歌翻译 以下为原文 To rehost an activation license you need to return the license first. Once you successfully return the license it will be added back to your account then you need to regenerate the license again for your standalone machine.The below AR has the steps to return an activation based license. http://www.xilinx.com/support/answers/60525.html |
嗨,蒂姆,请检查以下AR:http://www.xilinx.com/support/answers/61960.htmlThanks,Tushar.---------------------
-------------------------------------------------- -------------------------------------------------- ---如果帖子有助于解决您的问题,请将帖子标记为答案(“接受为解决方案”)。如果帖子引导您进入解决方案,请给予赞誉。从长远来看,这将有助于其他人 以上来自于谷歌翻译 以下为原文 Hi Tim, Please check the below AR: http://www.xilinx.com/support/answers/61960.html Thanks, Tushar. ---------------------------------------------------------------------------------------------------------------------------- Please mark the post as an answer ("Accept as solution") in case it helped resolve your query. Give kudos in case a post guided you to the solution. This will help others in the long run |
当前拥有许可证的计算机不再存在 - 灾难性硬件故障。
无法从以前的主机返回许可证。 此时我有什么选择? 如果没有,我发现很难相信软件的成本和这种情况的共同性可能发生。 以上来自于谷歌翻译 以下为原文 The machine that currently has the license no longer exists - catastrophic hardware failure. There's no way to return the license from the previous host. What are my options at this point? If there are none, I find it hard to belive given the cost of the software and the commonality of this situation possibly happening. |
你好@ hf4xinx
请通过以下链接打开服务请求。客户支持团队将在这里为您提供帮助。 http://www.xilinx.com/support/service-portal.html 以上来自于谷歌翻译 以下为原文 Hi @hf4xinx Please open a service request from the below link.Customer support team will be able to help you here. http://www.xilinx.com/support/service-portal.html |
只有小组成员才能发言,加入小组>>
2420 浏览 7 评论
2823 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2294 浏览 9 评论
3374 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2461 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1171浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
585浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
451浏览 1评论
2005浏览 0评论
729浏览 0评论
GMT+8, 2024-12-23 14:36 , Processed in 1.971898 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
