嗨,我是ICCAP软件的新用户。
我不知道如何准确编程。 我的问题如下:我模拟了三个DUT的电压和电流值。 所有电压扫描都是相同的(例如-1到1V,10个点),但模拟电流各不相同。 我想创建一个数组,其中包含特定电压点的三个DUT的电流值,这应该对所有电压点重复。 它还应该将上面创建的每个数组映射到具有三个元素的默认数组。 请给我一个提示我应该怎么做呢? 最诚挚的问候,Anurag 以上来自于谷歌翻译 以下为原文 Hi, I am new user to ICCAP software. I don't know how to program exactly in it. My question is as follows: I have simulated values of voltage and current's for three DUTs. Voltage sweep is same for all (e.g -1 to 1V, 10points), but simulated currents differ for each. I would like to create an array which contains values of currents from three DUTs at particular voltage point, and this should be repeated for all voltage points. It should also plot each array created above against a default array which has three elements. Please give me a hint how should I start with it?? Best Regards, Anurag |
1个回答
嗨Anurag,我很乐意提供帮助,但我不确定我是否完全遵循你的想法。
这类问题的最佳背景是联系我和我们的技术支持部门,而不是通过论坛进行讨论。 然后我们可以更轻松地讨论细节和交换电子邮件。 请发送电子邮件至:电子邮件:[else_schmidt@agilent.com]并复制电子邮件:[eesof_support@agilent.com]我将很乐意与您进一步讨论。 我认为可能有多种方法可以应用。 如果可以,请附上* .mdl文件和3个DUT,我们可以将其作为起点。 还建议你想要使用的电压点和默认阵列的内容。你的情节都只有3点吗? 请澄清..最好的问候 以上来自于谷歌翻译 以下为原文 Hi Anurag, I will be glad to help, but I am not sure I fully follow what you had in mind. The best context for this type of question, would be to contact me and our tech support department, rather than discuss it via the forum. Then we can more easily discuss the details and exchange emails. Please send me an email at : Email: [else_schmidt@agilent.com] and copy Email: [eesof_support@agilent.com] andI will be happy to discuss it further with you. I think there may be a variety of approaches which could be applied. If you can, please attach your *.mdl file with the 3 DUTs and we can use that as the starting point. Also suggest the voltage points you want to use and the contents of the default array.Your plots will all have only 3 points? Please clarify.. Best regards Else |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 19:47 , Processed in 0.663683 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2103
