板子为STM32F407. 在官网上下载了STMFlashLoader Demo.exe 和 STMFlashLoader.exe。把BOOT0置为1,通过STMFlashLoader Demo.exe可以成功下载程序。出于某些原因需要用命令行的方式。
同样BOOT0置为1. 命令行输入: STMFlashLoader.exe -c --pn 3 --br 115200 --co ON -Rts --Hi -Dtr --Lo -e --all -i STM32F4_05_07_15_17_1024K.STmap -d --a @08000000 --fn monitor.hex --v 但是提示无法擦除,哪位大神知道是什么原因呢?是哪里设置不对么? Opening Port [OK] Set Rts line [OK] Reset Dtr line [OK] the MapFile name is MapSTM32F4_05_07_15_17_1024K.STmap.STmap This version is not intended to support the rget Press any key to continue ... |
15个回答
不设置DTR和RTS后,
Opening Port [OK] ERASING STM32... Enter STBL_ERASE... erasing all pages [KO] the MapFile name is MapSTM32F4_05_07_15_17_1024K.STmap Activating device [OK] DOWNLOADING ... downloading page/sector 0 @0x 8000000 size 16.00(KB) [OK] downloading page/sector 1 @0x 8004000 size 16.00(KB) [OK] downloading page/sector 2 @0x 8008000 size 16.00(KB) [OK] downloading page/sector 3 @0x 800C000 size 16.00(KB) [OK] downloading page/sector 4 @0x 8010000 size 35.63(KB) [OK] disabling read protection [OK] reseting device [OK] 手动复位之后把Boot0置为0,无法启动。文件大小也不对,在window上显示有280KB。 有哪位大神知道嘛? |
发现stam的名字写错了,更改了下。
STMFlashLoader.exe -c --pn 3 --br 115200 --co ON -Rts --Hi -Dtr --Lo -e --all -i STM32F4_05_07_15_17_1024K -d --a @08000000 --fn monitor.hex --v 提示: Opening Port [OK] Set Rts line [OK] Reset Dtr line [OK] the MapFile name is MapSTM32F4_05_07_15_17_1024K.STmap Activating device [KO] No response from the target, the Boot loader can not be started. Please, verify the boot mode configuration, reset your device then try again. Please, reset your device then then press any key to continue |
加上擦除提示擦除失败。Opening Port [OK]
ERASING STM32... Enter STBL_ERASE... erasing all pages [KO] the MapFile name is MapSTM32F4_05_07_15_17_1024K.STmap Activating device [KO] No response from the target, the Boot loader can not be started. Please, verify the boot mode configuration, reset your device then try again. Please, reset your device then then press any key to continue |
学习学习
启动模式配置不正确。
rget 不是提示版本不支持么? |
版本不支持
提示模式配置不正确呀
学习学习
学习学习
提示模式配置不正确呀
第一次看见有人用这个命令行模式,真是学习了。
我的神,这里有高人,我想都没想到这都能做
请问这个问题解决了吗?能具体描述下解决方式吗,目前也在做用命令行升级STM8的程序,但是也遇到了类似的问题。求解答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 04:52 , Processed in 2.893138 second(s), Total 100, Slave 83 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6556
