使用闪存最糟糕的环境是什么?
以上来自于百度翻译 以下为原文 What kind of environment is the worst in using flash memory? |
3个回答
你好,山村,
一般来说,不建议在数据表中提到的操作条件之外使用该设备。因此,取决于你有商业、工业或汽车的设备,你应该在那些温度范围内操作。如果你操作超过它,它将不工作。 商用或工业设备不能用于军事应用,在这种情况下,它将被认为是特定设备的最坏环境。所以这取决于你拥有的设备。 希望它能回答你的疑问。 谢谢, Krishna。 以上来自于百度翻译 以下为原文 Hello Yamakoshi San, In general it is not recommended to use the device outside operating conditions mentioned in the datasheet. So depending on the device you have like commercial, Industrial or Automotive you should operate with in those temperature ranges. If you operate beyond that it will not work. A commercial or industrial device can not be used in military applications , in this case it will be considered a worst environment for the specific device. So it depends on the device you have. Hope it answers your query. Thanks, Krishna. |
60user47 发表于 2018-12-7 18:07 你好,奎师那山, 谢谢你的回复。 这将加速细胞在下列条件下的恶化? 除了下列条件之外,是否有任何与细胞退化有关的条件? 高电压或Low电压 高温或Low温度 ·P/E循环间隔快或慢 以上来自于百度翻译 以下为原文 Hello Krishna san, Thanks for your reply. Which will accelerate the deterioration of the cell under the following conditions? In addition to the following conditions, are there any conditions related to cell deterioration? ・High voltage or Low voltage ・High temperature or Low temperature ・P/E cycle interval is fast or slow |
你好,山村, 请参阅下面的链接中的我们的申请说明: HTTP://www. CyPress .COM/FIL/369306/下载 请注意这个应用笔记不使用数据保留和循环的绝对能力。在这种情况下,我们使用基线值。 对于高VCC和低VCC,即使Vcc不同,正常的单元电压应力也是常见的。因此,基本上没有细胞降解的关系。 对于P/E循环,如果快速,则细胞降解会更多。 谢谢, Krishna。 以上来自于百度翻译 以下为原文 Hello Yamokoshi san, Please refer to our application note from the link given below : http://www.cypress.com/file/369306/download Please note this app note doesn’t use absolute ability for data retention and cycling. we use baseline value in this case. For high Vcc and low Vcc, normally cell voltage stress is common even if Vcc is different. So, basically, there is no relation for cell degradation. Regarding P/E cycling if is fast the cell degradation will be more. Thanks, Krishna. |
只有小组成员才能发言,加入小组>>
726个成员聚集在这个小组
加入小组1938 浏览 1 评论
1685 浏览 1 评论
3448 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1606 浏览 6 评论
1404 浏览 1 评论
GMT+8, 2024-6-26 07:01 , Processed in 0.578308 second(s), Total 52, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
