在我的计算机上安装ISE 13.1的过程中,当软件安装加载程序进入步骤时,我会遇到一些问题,如下图所示.Mylaptopmodel isLenvoY460。当我将光标移动到框中时
在“我接受并同意上述条款和条件”之前,点击它,但它失败了,我无法点击它,。我尝试了很多次,但它失败了。我想知道原因,并且 怎么解决这个问题。 任何回复将不胜感激!非常感谢! 以上来自于谷歌翻译 以下为原文 In the process of installing ISE 13.1 on my computer,I encounter some problems when the software installation loading program progress to the step as the following image shown.My laptop model is LenvoY460.When I move the cursor to the box in front of the "I accept and agree to the terms and conditions above",and click it,but it failed,I can not click it,.I tried many times,but it failed as same.I want to know why,and how to solve that. Any reply will be appreciated!Thank you very much! |
5个回答
你能否点击下一个点击后得到的错误信息快照?谢谢,哈利
-------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Could you please post the error message snapshot which you get after clicking on next ? Thanks, Harry------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
请检查以下AR http://www.xilinx.com/support/answers/41817.html是否与相关的玩具问题有关
_______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 Please check whether the following AR http://www.xilinx.com/support/answers/41817.html is related to your issue ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
嗨,可能是一个损坏的下载问题。
你使用哪种操作系统? 要检查文件是否正确下载,下载文件的MD5校验和值应与下载文件的MD5总和值匹配(Xilinx网站 - >支持 - >下载).MD5sum可以从http:// www。 fastsum.com/将.tar文件提供给FastSum工具后,它将显示文件的Checksum state值。将校验和 state列值与Xilinx下载页面提供的值进行比较。 如果不匹配,则表示下载的文件未完成或已损坏。您必须再次从Xilinx网站下载Vivado。 http://www.xilinx.com/support/download/index.htm如果MD5校验和值与下载的文件匹配,则使用7zip软件解压缩,因为7-zip用于压缩软件。可以从http://下载 www.7-zip.org/(解压缩时请保持层次结构完整)建议在解压缩或解压缩下载文件时关闭防病毒软件。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, May be a corrupted download issue. By the way which OS are you using? To check if the file was downloaded correctly, MD5 checksum value of downloaded file should match with MD5 sum value from where file was downloaded (Xilinx website-->support-->download). MD5sum can be downloaded from http://www.fastsum.com/ After feeding your .tar file to FastSum tool, it will display Checksumstate value of file. Compare the checksumstate column value with the value provided at download page on Xilinx. If there is mismatch, it means that the downloaded files are not complete or corrupted. You must again download Vivado from Xilinx website. http://www.xilinx.com/support/download/index.htm If MD5 checksum value matches with downloaded file then Use 7zip software to unzip since 7-zip was used for zipping the software. It can be downloaded from http://www.7-zip.org/ (Please keep the hierarchy intact when unzipping) It is recommended to turn off anti-virus when unzipping or extracting downloaded file. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
还有一点要检查请尝试在您的本地目录中安装ISE可能是它正在使用网络路径。请使用C目录进行安装。复制整个tar文件&
在本地目录中解压缩。请尝试& 让我们知道结果。 如果您使用网络驱动器进行安装,有时会出现类似的问题。谢谢,哈利 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 One more point to be checked please try to install ISE in your local directory may be it is using the network path. Please use C directory for the installation. Copy the whole tar file & unzip in local directory. Please try & let us know the outcome. Sometimes there are similar issue if you us network drive for installation. Thanks, Harry------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
问题可能是机器特定的。
您也可以尝试批量模式安装,看看它是否可以解决问题。 - 要生成批处理脚本,从命令提示符/终端运行“batchxsetup(.exe)-samplebatchscript”,从安装程序/ bin / [PLATFORM] - 在文本编辑器中打开 - 在destination_dir =“LOCATION”中设置LOCATION到该位置 您希望安装ISE Design Suite - 根据您要安装的版本取消注释一组设置.-从命令提示符/终端导航到/ bin / [PLATFORM] - 键入./batchxsetup(.exe)-batch-在同意最终用户许可协议后,安装程序将继续安装您选择的工具。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 The problem is probably machine specific. You might as well try batch mode installation to see if it can work around the issue. - To generate the batch script, run "batchxsetup(.exe) -samplebatchscript -Open -Set LOCATION in destination_dir="LOCATION" to the location you wish to install ISE Design Suite -Uncomment a block of settings depending on which edition you would like to install. - From a command prompt/terminal and navigate to - Type ./batchxsetup(.exe) -batch -After agreeing to the End User License Agreement, the installer will proceed in installing the tools you selected. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2420 浏览 7 评论
2823 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2294 浏览 9 评论
3374 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2461 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1162浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
584浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
451浏览 1评论
2005浏览 0评论
729浏览 0评论
GMT+8, 2024-12-23 08:37 , Processed in 1.434394 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
