你好,
在无需使用BLE通信的应用程序中, 降低电力消耗的有效途径是什么? 在我的应用程序中不存在节电选项。 CYW20706是主要的主机,所以我不能使用深度睡眠模式。 应用程序使用周期性计时器(几十毫秒), 所以我不能使用低功耗睡眠模式。 请给我一些建议。 谢谢您! 以上来自于百度翻译 以下为原文 Hello, In a hands-free application using BLE communication, What is an effective way to reduce power consumption? The power save option is not available in my application. CYW20706 is the main host, so I can't use the deep sleep mode. And the application is using a periodic timer(several tens of milliseconds), so I can't use the low power sleep mode. Please give me some advice on waht to do. Thank you! |
4个回答
嗨,亚伦,
当你说“免提”时,你指的是HFP吗?你用BLE做什么? 你读过这篇文章了吗?CYW20706-BLE低功率信标 可以使用WiDDySLePySuffic()API来减少功耗,但是如果应用程序计时器总是在运行,那么我认为不会有任何功耗降低。 您应该通过改变TX功率或间隔或从等待时间(对于BLE)来减少功率。 以上来自于百度翻译 以下为原文 Hi Aaron, When you say 'handsfree' are you referring to HFP? What are you using BLE for? Have you read this article? CYW20706 – BLE Low Power Beacon You could use the wiced_sleep_config() API to reduce power consumption but if a applicaiton timer is running always, then I don't think there will be any power reduction. You should be looking at reducing power by changing Tx power or intervals or slave latency (for BLE). |
嗨,伊苏, 谢谢你的回复。 是的,HFP是正确的。 和BLE使用几个服务(GATT,串行GATT,ANCS等)来与智能手机应用程序通信。 我知道这篇文章。 我不希望使用WiDDySalePyCuffice()API来减少功耗, 我的应用程序有几个周期定时器 所以我问是否有其他方式,特别是在HFP中。 谢谢您。 以上来自于百度翻译 以下为原文 Hi yssu, Thank you for your reply. yes, HFP is right. And BLE uses several services(GATT, Serial GATT, ANCS, etc) to communicate with the smartphone app. I know the article. I don't expect to use wiced_sleep_config() API to reduce power consumption, My application has several periodic timers So I asked if there was any other way, especially in hfp. Thank you. |
在像HFP这样的音频应用程序中,没有什么可以减少功耗。 你可以降低TX的功率。除此之外,我想不出任何方法来减少当前的消费。 以上来自于百度翻译 以下为原文 There is nothing much you could do to reduce power consumption in an Audio application such as HFP. You could maybe reduce the Tx power. Apart from this, I cannot think of any ways to reduce the current consumption. |
谢谢,YSU。 以上来自于百度翻译 以下为原文 Thank you, yssu. |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2105 浏览 1 评论
1851 浏览 1 评论
3669 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1786 浏览 6 评论
1536 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
568浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
422浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
437浏览 2评论
383浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
915浏览 2评论
GMT+8, 2024-12-23 08:03 , Processed in 1.620672 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
