电子发烧友论坛扫一扫,分享给好友
这是一个非常基本的问题,但我无法让我的新Nexys 4板进行编程。
我为Vivado生成了一个webpack .xml许可证,并使用许可证管理器激活它。 我正在尝试实现随板提供的演示项目,但是我收到以下错误: [Common 17-345]找不到功能'Synthesis'和/或设备'xc7a100t'的有效许可证。 请运行Vivado License Manager以获取有关确定哪些功能和设备已获得系统许可的帮助。 我相信Vivado v14.2支持Nexys 4,xc7a100t芯片。 我该如何解决这个问题? 谢谢! 以上来自于谷歌翻译 以下为原文 This is a very basic problem, but I am having trouble getting my new Nexys 4 board to program. I generated a webpack .xml license for Vivado and activated it using the License Manager. I am trying to implement the demo project that came with the board, but I am getting the following error: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7a100t'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. I believe Vivado v14.2 support the Nexys 4, xc7a100t chip. How should I try to resolve this? Thanks! |
10个回答
webpack 2014.2支持Artix100t设备。
请确保您拥有运行2014.2的有效许可证。我猜您可能对许可证文件有版本限制以在2014年合成设计。请参阅http://forums.xilinx.com/t5/Installation-and -Licensing / Vivado-2013-3-can-t-find-license / td-p / 380081获取更多信息.Regards,Krishna -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 The webpack 2014.2 supports Artix100t device. Please make sure that you have a valid license to run 2014.2. I guess you may have a version limit on the license file to synthesize the design in 2014.2. Please refer to http://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2013-3-can-t-find-license/td-p/380081 for more information. Regards, Krishna----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
所以这是许可管理器下面显示的内容,如果它有帮助:
我不认为它是版本限制,因为它到2015.07,对吧? 以上来自于谷歌翻译 以下为原文 So this is what shows up under the license manager if it helps: I don't think it's a version limit since it goes to 2015.07, right? |
嗨,你能在tcl控制台中运行以下tcl命令并分享结果吗?1。
report_environment -file output.txt 2. xlicclientmgr -vThanks,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Can you run the below tcl commands in tcl console and share the outcome? 1. report_environment -file output.txt 2. xlicclientmgr -v Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
这是你需要看到的输出吗?
report_environment -file output.txtINFO:[Common 17-635]现在获取报告信息。 这可能需要一些时间:[通用17-633]获取系统信息...信息:[通用17-632]获取软件环境信息...信息:[通用17-629]获取Vivado首选项...信息 :[Common 17-630]获取安装信息... INFO:[Common 17-628]获取DLL信息... INFO:[Common 17-631]获取许可证信息... INFO:[Common 17-634] Done 获取报告信息.xlicclientmgr -vWARNING:[Common 17-259]未知Tcl命令'xlicclientmgr -v'向OS shell发送命令以执行。如果不信任,则查看应用程序可信存储.U D如果禁用。 。 fulfillmentType。 。 。 到期计数FulfillmentId ProductId。 。 6永久0 211458705 209855574查看1个履行记录中的1个。 以上来自于谷歌翻译 以下为原文 Is this the output you need to see? report_environment -file output.txt INFO: [Common 17-635] Now fetching report information. This may take some time. INFO: [Common 17-633] Fetching system information... INFO: [Common 17-632] Fetching software environment information... INFO: [Common 17-629] Fetching Vivado preferences... INFO: [Common 17-630] Fetching installation information... INFO: [Common 17-628] Fetching DLL information... INFO: [Common 17-631] Fetching license information... INFO: [Common 17-634] Done fetching report information. xlicclientmgr -v WARNING: [Common 17-259] Unknown Tcl command 'xlicclientmgr -v' sending command to the OS shell for execution. Viewing application trusted storage. U if untrusted . D if disabled . . fulfillmentType . . . Expiry Count FulfillmentId ProductId . . 6 permanent 0 211458705 209855574 Viewed 1 of 1 fulfillment records. |
嗨,在这里附上生成的output.txt。你会发现这是工作目录[pwd]。谢谢,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Attach the generated output.txt here. You will find this is present working directory [pwd]. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,
从output.txt我们可以看到,对于许可证功能Vivado_WebPACK,主机ID不匹配。 您是否在生成基于激活的Vivado WebPack许可证时使用了Dongle? 加密狗是否还在插上机器? 问候, 肖恩 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi, From the output.txt we can see that for license feature Vivado_WebPACK, Host ID does not match. Were you using Dongle when you generated the Activation based Vivado WebPack license? Is the dongle still pluging on the machine? Regards, Sean ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
嗨,
您需要重新托管许可证。 为此,您将使用AR#60525中的步骤将旧的Vivado WebPack许可证返回给Xilinx,然后生成一个新许可证。 问候, 肖恩 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi, You need to re-host the license. In order to do that you will return the old Vivado WebPack license to Xilinx with the steps in AR# 60525 and then generate a new one. Regards, Sean ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3141 浏览 7 评论
3435 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2897 浏览 9 评论
4097 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3082 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1358浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1196浏览 1评论
/9
GMT+8, 2025-12-11 08:47 , Processed in 0.975567 second(s), Total 91, Slave 74 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3216
