电子发烧友论坛|
喜
我正在尝试使用单线核心测试电源pc405上的Web服务器设计的参考XUPV2P设计之一。 我有一个XP操作系统运行机器,我安装了ISE 7.1,edk 7.1,然后将其升级到Service Pack 1.但我的机器是一个服务包3.如何安装成功,但当我尝试打开平台工作室时,它给出 我说错了 “应用程序无法启动,因为找不到libxdh_partAnno.dll。重新安装应用程序可能会解决此问题”我尝试过多次但失败了。 你们其中一个人可以给我一个灵魂,因为我绝望地试验这个项目的设计...... 谢谢 伊曼尼 以上来自于谷歌翻译 以下为原文 hi, I am trying to test one of the refernce XUPV2P design of Web server design on power pc405 with a one wire core. I have a XP operating system running machine and I installed ISE 7.1 , edk 7.1 and then upgrade it in to service pack 1. but my machine is a service pack 3. how ever installation was successful but when I try to open platform studio it give me an error saying "the application has failed to start because libxdh_partAnno.dll was not found. re install the application may fix this problem" I tried many times but failed. Could one of you pls give me a soultion as I am desparate to trial this design for a project... thanks imani |
1个回答
ISE 7.1i不支持XP,SP3。
但是,错误消息听起来更像是安装错误(文件丢失)或环境设置不正确。 如果您搜索驱动器,您会找到libxdh_partAnno.dll吗? 如果是这样,它所在的目录是否包含在PATH变量中? 如果找不到.dll,则可能需要重新安装。 以上来自于谷歌翻译 以下为原文 XP, SP3 was not supported for ISE 7.1i. However, the error message sounds more like either a bad installation (files missing) or the environment is not set up correctly. If you search you drive do you find libxdh_partAnno.dll? If so, is the directory where it is located, included in the PATH variable? If, the .dll is not found, a re-install may be needed. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 22:23 , Processed in 1.348176 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
453
