你好,Techteam
我们已经在产品上使用了NOR闪存AM29 F032。这几年发生了两次奇怪的事件。当程序只读取闪存时,一些地址单元的数据全部变成0x00。地址地址单元如下: 1号产品 0x1-0x4FE40 0x4FE81-0x4FF40 产品2号 0x1-0xF4240 0xF4301-0xF43E 我们确信我们的时序设计是正确的,因为数据表被告知。你能解释一下这个事件的原因吗?非常感谢! 以上来自于百度翻译 以下为原文 Hello, Techteam We've been using the NOR Flash AM29F032B for several years on our products. A strange event has been occurred twice during these years. Data of some address units all turned into 0x00 when the programm only read the flash. The throuble address units are as follow: Product No.1 0x1--0x4FE40 0x4FE81--0x4FF40 Product No.2 0x1--0xF4240 0xF4301--0xF431E We are sure that our timing design is correct as the datasheet informed. Could you please explain the reason for this event? Thank you very much! |
2个回答
你好,唐,
请澄清以下疑问: 你观察了多少设备? 你刚才提到的问题只有两次。当您尝试在这些位置编程新数据时,您能够读取正确的数据。 谢谢, 奎师那。 以上来自于百度翻译 以下为原文 Hello Tang, Please clarify the below queries : On how many devices did you observe the issue. You have mentioned the issue happened only twice. When you try to program the new data in those locations were you able to read the correct data. Thanks, krishna. |
你好,奎师那, 谢谢你的回复。我们生产了400个设备,每个设备都有一个闪存芯片。数据是一个月前写的,当我们检查它们(刚刚阅读测试)时,问题就发生了。2个设备出了问题。我们重新定位的位置,并再次读取数据正确。我们真的很努力去测试芯片,但是这个问题再也没有发生过。这对我们来说是个谜。 以上来自于百度翻译 以下为原文 hi krishna, thank you for the reply. We produced 400 devices and each of them has one flash chip. The data were written one month ago and when we checked them(hy just reading test)the issue happend. 2 devices got the problem. We reprogramed the locations and the data were read correct again. We tried really hard to test the chip but the issue never happened again. It's a mystery to us now. |
只有小组成员才能发言,加入小组>>
737个成员聚集在这个小组
加入小组1963 浏览 1 评论
1717 浏览 1 评论
3483 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1644 浏览 6 评论
1432 浏览 1 评论
GMT+8, 2024-8-5 20:19 , Processed in 0.638678 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
