我有一个8 GB RAM的NUC7i3BNK和一个三星960 EVO SSD。
我想在其上安装Windows 10 Home。 安装正常启动,然后卡在“准备安装文件(%52)”中。 附加信息: 1)我使用今天下载的Windows Media Creation工具创建可启动的USB记忆棒 2)我对最新版本执行了F7 BIOS更新(今天下载) 3)我试了5次(也用不同的棍子),安装总是以相同的百分比停止(52%) 4)我能够正确安装Ubuntu,所以我认为硬件没问题 有没有办法(例如日志文件)找出失败的原因? 它必须是非常具体而非随机的东西。 这个百分比值会触发任何猜测吗? 谢谢 以上来自于谷歌翻译 以下为原文 I have a NUC7i3BNK with 8 GB RAM and a Samsung 960 EVO SSD. I want to install Windows 10 Home on it. The installation starts properly but then gets stuck at 'Getting files ready for installation (%52)'. Additional information: 1) I used the Windows Media Creation tool downloaded today for creating a bootable USB stick 2) I performed an F7 BIOS Update to the newest version (downloaded today) 3) I tried 5 times (also with different sticks) and the installation always stops at the same percentage (52%) 4) I was able to install Ubuntu properly, so I assume that the hardware is ok Is there a way (e.g. a log file) to find out the reason for this failure? It must be something very specific and not random. Does this percentage value trigger any guesses? Thank you |
9个回答
它是一个干净的安装或安装在其他东西,如Windows 7?
以上来自于谷歌翻译 以下为原文 Is it a clean install or an install over something else, such as Windows 7? |
不能是Windows 7,因为第7代和更高版本的处理器仅支持Windows 10。 文件 以上来自于谷歌翻译 以下为原文 Could not be Windows 7 as only Windows 10 is supported on 7th gen and later processors. Doc |
是的,当然,你是对的。 有时过度安装会违反预先存在的软件,特别是病毒防护,所以我只想消除它。 听起来好像它实际上是一个干净的安装,在这种情况下,我不知道答案。 以上来自于谷歌翻译 以下为原文 Yes, of course, you are correct. Sometimes an over install will fall foul of pre-existing software, especially virus protection so I was just wanting to eliminate that. It sounds to to me as though it actually is a clean install, in which case I do not know the answer. |
安伦天嘻嘻 发表于 2018-11-29 13:04 这是一个超级干净的安装到原始SSD。 我不知道它是否重要但我应该提到8 GB RAM是一个单独的内存模块。 根据英特尔文档,这是可能的。 以上来自于谷歌翻译 以下为原文 It is a super clean install onto a virgin SSD. I don't know whether it matters but I should mention that the 8 GB RAM is one single memory module. According to the Intel documentation this is possible. |
1.根据您的定义,您在新SSD上安装Windows,但是在第一篇文章中您提到Linux已安装在此SSD上? 请验证您的安装是否符合以下教程中定义的步骤:Windows 10帮助论坛。 在开始安装之前,请将您的BIOS设置为默认设置(应启用UEFI启动)。 跳过段落。 本教程中的12(传统启动)并继续执行第13段(UEFI启动)。 注意para.13.A(删除所有现有分区),然后按Next。 莱昂 以上来自于谷歌翻译 以下为原文 1. Per your definition you are installing Windows on new SSD, however in the first post you have mentioned that Linux was installed on this SSD? Please verify if your installation is according to steps defined in the following tutorial: Windows 10 Help Forums . Before starting installation, please set your bios to default settings (UEFI boot should be enabled). Skip on para. 12 (legacy boot) in this tutorial and continue to para 13 (UEFI boot). Pay attention on para.13.A (delete all exiting partitions) and then press Next. Leon |
飞雪9366 发表于 2018-11-29 13:32 嗨莱昂, 抱歉长时间休息,我没有时间跟进。 是的,安装已启动到新的SSD上,并且在每次尝试时都删除了所有分区。 我在Windows 10尝试失败后才安装了Ubuntu以确保硬件正常。 今天我再次尝试了三次,从W10 Home切换到W10 Pro,但唯一的变化是安装可重复地停留在50%而不是52%...... 不幸的是我没有匹配的RAM或SSD来做替换游戏。 叫我幸运,但我已经安装了Windows系统25年了,从来没有遇到任何问题。 但因此解决问题的经验也不多。 我无法相信没有安装日志来获取信息。 任何想法? 问候 HJ 以上来自于谷歌翻译 以下为原文 Hi Leon, sorry for the long break, I did not have the time to follow up. Yes, the installation was started onto a new SSD, and at each attempt, all partitions were removed. I only installed Ubuntu after n unsuccessful tries with Windows 10 to ensure the hardware is ok. I tried again three times today, switching from W10 Home to W10 Pro, but the only change is that the installation reproducibly gets stuck at 50% instead of 52%... Unfortunately I do not have matching RAMs or SSDs to do the replacement game. Call me lucky, but I have installed Windows systems for 25 years now and never had any problems. But therefore also not much experience with problem solving. I cannot believe that there is no installation log to get information from. Any idea? Regards Hj |
你好Hj 1.可能是您的安装介质已损坏。 准备一个新的。 使用其他USB记忆棒。 2.断开非必要的USB设备(HUB,外部磁盘......) 2.请将您的BIOS重置为默认设置(应启用UEFI启动)。 3.启动时(插入安装介质USB),按F10键进入启动菜单。 4.在Boot Menu中,选择安装USB的UEFI选项,然后按enter键。 5.按照上面第5篇文章中的教程进行操作。 问候 莱昂 以上来自于谷歌翻译 以下为原文 Hello Hj 1. Could be that your Installation Media is corrupted. Prepare a new one. Use other USB stick. 2. Disconnect non essential USB devices (HUB, external disk,...) 2. Please reset your Bios to default settings (UEFI boot should be enabled). 3. While booting (with Installation Media USB inserted), press F10 to get Boot Menu. 4. In Boot Menu chose UEFI option of your installation USB and press enter. 5. Follow the tutorial from my post #5 above. Regards Leon |
嗨莱昂, 的确,这是安装媒介! 虽然我从一开始就尝试过两种不同的USB记忆棒,但我认为最不可能成功的变种带来了突破。 我已经开始使用64 GB TDK USB记忆棒,当这不起作用时,尝试使用相同类型的另一个。 只有这个周末,当我已经非常绝望的时候,我给了一个SanDisk microSD卡的机会,我不得不从Raspberry Pi中划出来。 我把它放在这些卡中的一个很小的,不太可靠的适配器中,它确实有效。 非常感谢您的帮助! 还有一个问题:在安装过程中无法读取之前工作过的USB记忆棒是什么? 我已经阅读过启动过程中的问题,但我不记得有关“批量阅读”的任何内容。 最好的祝福 HJ 以上来自于谷歌翻译 以下为原文 Hi Leon, indeed, it was the installation medium! Although I had tried it with two different USB sticks right from the start, it was the variant that I thought least likely to succeed which brought the breakthrough. I had started with a 64 GB TDK USB stick and when this did not work, tried it with another one of the same type. Only this weekend, when already pretty desperate, I gave a chance to a SanDisk microSD card which I had to scratch out of a Raspberry Pi. I put it into one of these tiny, not too reliable looking adapters coming with these cards and it really worked. Many thanks for your help! One more question though: How can it be that USB sticks that have worked before and are working still, cannot be read during installation? I have read about problems during booting, but I cannot remember anything about 'bulk reading'. Best regards Hj |
你很高兴你成功了。 我怀疑问题可能在安装介质中,因为安装被中断,从这个介质读取。 我不知道会出现什么问题? 在它上运行一个检查盘可能是好的,寻找坏道? 尝试使用SD Formatter工具格式化此USB:SD存储卡格式化程序 - SD关联。 这也适用于USB。 莱昂 以上来自于谷歌翻译 以下为原文 I'm glad that you have succeed. I suspected that the problem may be in installation media, since the installation was interrupted, reading from this media. I don't know what could be the problem? May be is good to run a checkdisk on it, looking for bad sectors? Try to format this USB using SD Formatter tool: SD Memory Card Formatter - SD Association . This is good for USB too. Leon |
只有小组成员才能发言,加入小组>>
382浏览 0评论
GMT+8, 2024-9-28 22:55 , Processed in 0.820157 second(s), Total 94, Slave 78 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
