电子发烧友论坛|
您好,我有几个U1272A可供我使用,并希望自动获取他们的读数。
我有足够的IR-USB适配器,它们确实显示为串行设备。 我的问题是:如何从U1272A获得测量/读数? 目标是自动化测量,进入excel表(但需要更广泛的兼容性)。 我知道这些设备支持SCPI命令的子集,如果我将它们发送到正确的COM端口,我应该得到适当的响应。 事实上,它在发送* IDN时有效(有时)。 这个万用表是否有专门支持的命令列表? 我看了很多,从来没有找到一个详尽的命令列表(对于这个特定的设备或一般的SCPI)。 我安装了Agilent IO Suite以及Agilent Command Expert。 有了这些,我可以使用交互式IO发送和读取命令(只是,因为我不知道除了* IDN之外我没有得到多少命令?)。 我已经尝试通过注册设备在Excel中使用Command Expert面板,但似乎我无法连接到设备(即使它显示在Command Expert独立版中)。 任何帮助将非常感激,因为有关这方面的材料是非常稀缺的。 以上来自于谷歌翻译 以下为原文 Hello, I have several U1272A's at my disposal and would like to automatically get readings from them. I have enough IR-USB adapters and they indeed show up as serial devices. My question is: How do I get measurements/readings from the U1272A? The goal being to automate measurements, into an excel sheet (but a broader compatibility is wanted). I understand these devices support a sub-set of the SCPI commands and if I send them one to the correct COM port, I should get an appropriate response. In fact, it does work (sometimes) when sending *IDN?. Is there a list of the commands support specifically by this multimeter? I've looked a lot and never could find an exhaustive list of commands (be it for this particular device or SCPI in general). I have installed the Agilent IO Suite as well as Agilent Command Expert. With these, I can use the Interactive IO to send and read commands (only, as I do not know the commands I don't get much other than *IDN?). I have tried using the Command Expert panel in Excel by registering the device, but it seems I cannot connect to the device (even if it shows up in the Command Expert standalone). Any help would be greatly appreciated as materials regarding this is quite scarce. |
1个回答
只有android APP能够处理多个连接。
如果您是某种软件大师,请查看此APP以获取答案。 以上来自于谷歌翻译 以下为原文 Only the android APP is capable to handle multiple connections. If you are some sort of a software Guru, check this APP for answers. |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 15:50 , Processed in 0.621618 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1252
