电子发烧友论坛|
我最近用一系列新的安捷伦设备更新了我的工作台。
到目前为止,我很享受自己,但我对我的新U1271A的阻力设置有一个奇怪的意义。 如果我在“自动”模式下短接引线,我将测量大约.15欧姆。 正常和预期的行为。 当我按下“范围”按钮时,会发生有趣的事情。 当我反复按下范围按钮来改变范围时,我似乎保留了一两个数字,意味着在最低范围内,我会看到.15欧姆的读数,但是如果引线短,我会得到“0.006”的读数 “3k范围和3 meg范围内的”0.0002“。 这意味着3兆范围内的短读数为200欧姆。 我把这个单元带到了经销商那里,我们都抓住了这个行为。 然后,我们将经销商的U1273A从展示柜中拿出来并观察到类似的行为。 我们错过了什么吗? 也许某个设置会导致这种意外行为? 也许它需要固件更新? 任何建议都会有所帮助,因为这种行为会导致我在使用此仪表时倾向于阅读我的读数。 提前感谢您提供的任何帮助。 以上来自于谷歌翻译 以下为原文 I've recently updated my bench with a host of new Agilent equipment. So far, I'm enjoying myself but I have one oddity with the resistance setting on my new U1271A. If I short the leads in "Auto" mode, I'll measure roughly .15 ohms. Normal and expected behaviour. The interesting thing happens when I press the "Range" button. As I press the range button repeatedly to change ranges, I seem to retain a digit or two, meaning on the lowest range I'll see a reading of .15 ohms but with the leads short, I'll get a reading of "0.006" on the 3k range and "0.0002" on the 3 meg range. That means a short reads 200 ohms on the 3 meg range. I brought the unit to the dealer and we all scratched our heads at this behaviour. We then got the dealer's U1273A out of the show case and observed a similar behaviour. Are we missing something? Perhaps a certain setting cause this unexpected behaviour? Perhaps it requires a firmware update? Any advice would help as this behaviour causes me to tend to dought my readings when using this meter. Thanks in advance for any help you could provide. |
1个回答
我敢打赌,在U1273A测试中,没有人有想法使用智能欧姆功能,它可以自动补偿测试引线电阻。
无论如何,U1271A没有Smart Ohm功能。 使用它的正确方法是在测试引线交叉时激活Null功能,只要开始测量实际电阻,测量就会很好。 以上来自于谷歌翻译 以下为原文 I bet that at the U1273A test, no one had the idea to use the Smart Ohm function, Which does automatic compensation of the test leads resistance. Any way, the U1271A does not have Smart Ohm function. The proper way to use it, is to activate the Null function with your test leads crossed, and your measurements will be fine, as long you start measuring real resistors. |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 15:19 , Processed in 0.524987 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1848
