电子发烧友论坛扫一扫,分享给好友
嗨,我能够在Windows 8的PC上安装Xilinx 14.6。为了将许可证加载到许可证管理器,我必须做一些技巧,但我可以使用Xilinx并毫无困难地启动新项目。
问题是,现在我发现我的程序在任何时候使用“打开项目”或“添加源”时都会崩溃有没有办法避免它? 以上来自于谷歌翻译 以下为原文 Hi, I was able to install Xilinx 14.6 on my PC with Windows 8. Had to do some tricks in order to load the license to the License Manager, but I could use Xilinx and initiate a new project without any trouble. The thing is, now i discovered that my program crashes any time I use "Open Project" or "Add Source" Is there any way to avoid it? |
1个回答
你好
Windows 8不支持操作系统,可能有这样的问题。 请查看以下支持的操作系统的Pdf。 http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/irn.pdf 另请查看下面的帖子,其中有工作现场,但官方不支持。 http://forums.xilinx.com/t5/Installation-and-Licensing/Xilinx-ISE-14-2-and-Windows-8/m-p/321181#M4506 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi Windows 8 is not supported OS and can have issue like this. Have a look at the below Pdf for thesupported OS. http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/irn.pdf Also have a look at the below post where work arounds are present but officially it is not supported. http://forums.xilinx.com/t5/Installation-and-Licensing/Xilinx-ISE-14-2-and-Windows-8/m-p/321181#M4506 Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2900 浏览 9 评论
4108 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1363浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1202浏览 1评论
/9
GMT+8, 2025-12-15 10:49 , Processed in 0.950122 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
11347
