嗨,我正在使用InfiniiVision MSO7104A示波器,并发现,“水平位置控制”****不时停止工作。
我正在做的是,我有一个信号在其中一个通道中运行,我按“运行/停止”停止采集数据。 然后我可以平移并放大所获取的数据。 我使用“水平位置控制”****来平移。 在它停止工作之前,这个****会运行一段时间。 当它停止工作时,其他旋钮/按钮仍然有效:我仍然可以放大/缩小等,但我不能左/右移动波形。 我不知道如何使这个“水平位置控制”****再次工作。 通常情况下我会关闭和关闭范围,之后这个****会再次正常工作。 但问题是我之前捕获的波形消失了,我不得不做一个新的捕获。 任何关于如何使“水平位置控制”****再次工作而没有动力循环范围的想法? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I am using InfiniiVision MSO7104A scope, and find that, from time to time,"horizontal position control" **** stops working. What i am doing is that, I have a signal running in one of the channels, and I press "Run/Stop" to stop acquiring data. Then I can pan across and zoom in on the acquired data. I use "horizontal position control" **** to pan across. This **** would work quite well for some time, before it stops working. When it stops working, other knobs/ buttons still works: I can still zoom-in/ zoom-out etc, but I cannot move the waveform left/ right. I don't know how to make this "horizontal position control" **** work again. Normally i would power off and on the scope, after which this **** works normally again. But the problem is that my previous captured waveform is gone, and i have to do a new capture. Any idea on how to make "horizontal position control" **** work again without power-cycling the scope? Thanks. |
1个回答
首先,确保您拥有最新的固件。
有关信息,请访问:http://www.home.agilent.com/agilent/software.jspx?ckey = 666864& cs = eng& cc = US& nid = -33562.753828& id = 666864如果您有最新信息, 那么你可能有硬件问题。 你没有说你有多远,或者有多快。 可能存在SW问题,因为您正在溢出一些内部计数器。 无论如何,我以前从未听说过这个,我怀疑会有新版本的SW发布。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 First, make sure you have the most recent firmware. Information is available here: http://www.home.agilent.com/agilent/software.jspx?ckey=666864&lc=eng&cc=US&nid=-33562.753828&id=666864 If you have the latest, then you may have a HW problem. You don't say how far you pan, or how fast. There may be a SW problem, in that you are overflowing some internal counter. In any case, I have never heard of this before, and I doubt there will be a new version of SW released. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
只有小组成员才能发言,加入小组>>
1070 浏览 0 评论
2306 浏览 1 评论
2093 浏览 1 评论
1967 浏览 5 评论
2838 浏览 3 评论
837浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
616浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
713浏览 0评论
1397浏览 0评论
1071浏览 0评论
GMT+8, 2024-9-29 22:19 , Processed in 1.237115 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
