电子发烧友论坛|
我有一个41952B 75欧姆T / R测试装置,并想验证它是否正常运行。
(我正在使用4195A网络分析仪)操作说明有一个基本方法:第3节操作:3-4操作员检查然而,它为非专家留下了很多。 (我擅长模拟音频电子设备和一点点无线电 - 但没有天线和RF。所以虽然对T / R只有非常基本的了解,但我基本上需要一步一步地对分析仪进行检查。 ,步骤如下:1。将设备连接到分析仪,测试端口未连接.2。将分析仪停止和启动频率分别设置为10和500 mHz 3.将分析仪输出电平设置为0 dBm 4. *“网络分析仪的幅度比读数 应该大约为0 dB。“* 5.将75欧姆(我有B单元)终端连接到测试端口.6。*”网络分析仪的幅度比读数应小于-30 dB“*可能更简单 ?但是我有一些问题: - 我使用NETWORK配置然后是S11吗? - 幅度比=“T / R”=发射电平除以反射电平吗?我想我看到了T / R和相角的绘图 (试图记住) - 我是否需要完成手册前面出现的CALIBRAtiON步骤“ 在我做扫描之前“零事” 实际上我真正需要的是实际按钮序列。 SPECTRUM对我来说很容易,因为我几乎知道我在做什么,所有控件都是熟悉的概念。 但NETWORK的东西对我来说都是新的。 先谢谢你,汤姆 以上来自于谷歌翻译 以下为原文 I have a 41952B 75ohm T/R Test Set and want to verify that it is functioning properly. (I'm using a 4195A Network Analyzer) The Operation Note has a basic method: Section 3 Operation: 3-4 Operator's Check however, it leaves a lot out for the non-expert. (I'm skilled in analog audio frequency electronics and a little radio - but no antennas and RF. So while having only a very basic understanding of T/R, I basically need a step by step to do the checkout on the analyzer. Paraphrasing, here are the steps: 1. Connect unit to analyzer with Test Port unconnected. 2. Set analyzer Stop and Start frequency to 10 and 500 mHz respectively 3. Set analyzer Output level to 0 dBm 4. *"The network analyzer's magnitude ratio reading should be approximately 0 dB."* 5. Connect a 75 ohm (I have the B unit) termination to the Test Port. 6. *"The network analyzer's magnitude ratio reading should be less than -30 dB"* What could be simpler? But here are some questions I have: - Do I use the NETWORK configuration and then S11? - does magnitude ratio = "T/R" = Transmitted level divided by Reflected level? I think I saw plotting of T/R and Phase Angle (trying to remember) - Do I need to go through the CALIBRATION step(s) that appear earlier in the manuals to "zero things out" before I do the sweep? Actually what I really need is the actual button sequence to do this. SPECTRUM is easy for me since I know pretty much what I'm doing and all the controls are familiar concepts. But the NETWORK stuff is all new to me. Thanks in advance, Tom |
1个回答
我不知道VNA或程序,但我怀疑*这要求你做的是用校准套件校准VNA(可能是85036B)。
当您在75欧姆负载下终止测试端口时,理想情况下应该没有反射信号,因此-30 dB的S11是合理的。 有三件事可以接近0 dB。 *在端口1打开的情况下测量S11。 (这是零dB,因为几乎所有信号都将从端口1反射出来)*测量S11时端口1短路。 (这是零dB,因为几乎所有信号都将从端口1反射出来)*测量S21,端口1连接到端口2(这是零dB,因为几乎所有信号都从端口1传输到端口2)如果您有几个衰减器 ,尝试测量它们的S11,一个连接器刚刚打开反射信号的幅度应该是衰减的两倍,因此6 dB衰减器的回波损耗为12 dB,因此S11的幅度约为-12 dB 。 S21应具有相同的幅度,但与衰减符号相反,因此10 dB衰减器将显示S21 = -10 dB。 *小心不要将75欧姆N连接器连接到50欧姆N连接器。* 50欧姆N插头的公引脚直径比75欧姆插座中的母头大,因此公头50欧姆插头会损坏母头75 欧姆插座。 如果你在50欧姆的女性中使用男性75欧姆,你将得到一个糟糕的连接。 有一个75欧姆的插头设计,将与50欧姆的插头配对,没有损坏。 但除非你100%确定你有它们,否则小心不要损坏你的设备。 对不起,我不能再提供任何帮助了。 我从未见过那个VNA。 Dave编辑:drkirkby于2013年7月30日9:02 PM编辑:drkirkby于2013年7月30日9:07 PM 以上来自于谷歌翻译 以下为原文 I don't know the VNA, or the procedure, but what I *suspect* this is asking you to do is to calibrate the VNA with a calibration kit (probably 85036B). When you terminate the test port in a 75 Ohm load, there should ideally be no reflected signal, so an S11 of -30 dB would be reasonable. There are three things that would give close to 0 dB. * Measure S11 with a port 1 open. (This is zero dB since almost all signal would be reflected from port 1) * Measure S11 with a port 1 shorted. (This is zero dB since almost all signal would be reflected from port 1) * Measure S21 with port 1 connected to port 2 (This is zero dB since almost all signal is transmitted from port 1 to port 2) If you have a few attenuators, trying measuring S11 of them, with one connector just left open The magnitude of the reflected signal should be twice the attenuation, so a 6 dB attenuator would have a return loss of 12 dB and so the magnitude of S11 will be around -12 dB. S21 should have the same magnitude, but opposite sign to the attenuation, so a 10 dB attenuator would show S21 = -10 dB. *Be careful not to mate 75 Ohm N connectors to 50 Ohm N connectors.* The male pin of a 50 Ohm N plug has a larger diameter than a female in a 75 Ohm socket, so the male 50 Ohm plug will damage a female 75 Ohm socket. If you use a male 75 Ohm in a female 50 Ohm, you will get a poor connection. There is a design of 75 Ohm plug which will mate with a 50 Ohm one without damage. But unless you are 100% sure you have them, be careful not to damage your equipment. Sorry I can't be of any more help. I've never met that VNA. Dave Edited by: drkirkby on Jul 30, 2013 9:02 PM Edited by: drkirkby on Jul 30, 2013 9:07 PM |
只有小组成员才能发言,加入小组>>
291 浏览 0 评论
1871 浏览 0 评论
2757 浏览 1 评论
2658 浏览 1 评论
2478 浏览 5 评论
1871浏览 0评论
434浏览 0评论
298浏览 0评论
/9
GMT+8, 2025-12-15 09:40 , Processed in 0.795687 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6708
