电子发烧友论坛|
设备是MZ2048 DAH169,哪里会出现问题?/错误的装置?
以上来自于百度翻译 以下为原文 /*** DEVCFG0 ***/ #pragma config DEBUG = OFF #pragma config JTAGEN = OFF #pragma config ICESEL = ICS_PGx2 #pragma config TRCEN = OFF #pragma config BOOtiSA = MIPS32 #pragma config FECCCON = OFF_UNLOCKED #pragma config FSLEEP = OFF #pragma config DBGPER = PG_ALL #pragma config SMCLR = MCLR_NORM #pragma config SOSCGAIN = GAIN_LEVEL_3 #pragma config SOSCBOOST = ON #pragma config POSCGAIN = GAIN_2X #pragma config POSCBOOST = ON #pragma config POSCFGAIN = GAIN_G3 #pragma config POSCAGCDLY = POSCAGCDLY1 #pragma config POSCAGCRNG = RANGE_1X #pragma config POSCAGC = OFF #pragma config EJTAGBEN = NORMAL #pragma config CP = OFF error: unknown configuration setting: 'POSCFGAIN' #pragma config POSCFGAIN = GAIN_G3 error: unknown configuration setting: 'POSCAGCDLY' #pragma config POSCAGCDLY = POSCAGCDLY1 error: unknown configuration setting: 'POSCAGCRNG' #pragma config POSCAGCRNG = RANGE_1X error: unknown configuration setting: 'POSCAGC' #pragma config POSCAGC = OFF Device is MZ2048DAH169, where can be problem?. ;/ wrong device? |
6个回答
你是否为和声配置器添加了正确的插件?应该是:2.0.5.2为和声2.05。
以上来自于百度翻译 以下为原文 Did you add the correct plugin for harmony configurator? Should be: 2.0.5.2 for Harmony 2.05. |
是的,我有2.0.5.2。如果你找到一点时间,那么请尝试为PIC32 MZ2048 DAH169创建新的和声项目(可以是空的)。运行和谐,并设置时钟配置的东西。尝试编译它,如果你没有得到错误,然后通过我为他们做什么/**DEVCFG0***
以上来自于百度翻译 以下为原文 Yes, I have 2.0.5.2 If you find a bit time then please try to made new harmony project (can be empty) for PIC32MZ2048DAH169. Run Harmony and set something in clock configuration. Try to compile it, and if you don't get error then past me what they do for /*** DEVCFG0 ***/ |
在4个DVCFG0参数中,我得到了错误
以上来自于百度翻译 以下为原文 I get error in 4 DEVCFG0 parameters "C:Program Files (x86)Microchipxc32v1.44binxc32-gcc.exe" -g -x c -c -mprocessor=32MZ2064DAH169 -ffunction-sections -O1 -I../src -I../src/system_config/default -I../src/default -I../../../../framework -I../src/system_config/default/framework -MMD -MF build/default/production/_ext/1688732426/system_exceptions.o.d -o build/default/production/_ext/1688732426/system_exceptions.o ../src/system_config/default/system_exceptions.c -DXPRJ_default=default -no-legacy-libc ../src/system_config/default/system_init.c:75:9: error: unknown configuration setting: 'POSCFGAIN' #pragma config POSCFGAIN = GAIN_G3 ^ ../src/system_config/default/system_init.c:76:9: error: unknown configuration setting: 'POSCAGCDLY' #pragma config POSCAGCDLY = POSCAGCDLY1 ^ ../src/system_config/default/system_init.c:77:9: error: unknown configuration setting: 'POSCAGCRNG' #pragma config POSCAGCRNG = RANGE_1X ^ ../src/system_config/default/system_init.c:78:9: error: unknown configuration setting: 'POSCAGC' #pragma config POSCAGC = ON ^ make[2]: *** [build/default/production/_ext/1688732426/system_init.o] Error 1 make[2]: *** Waiting for unfinished jobs.... |
嗨,埃内斯托,请安装最新的XC32 1.44支持你的操作系统补丁文件,并尝试重新编译。最好的问候。
以上来自于百度翻译 以下为原文 Hi Ernesto, please install latest xc32 1.44b support patch file for your operating system and try to compile again. Best regards. |
我确认。在1.44 b中,这个配置位可以正常工作。
以上来自于百度翻译 以下为原文 I confirm. On 1.44b works OK with this config bits. |
V2.05版本需要安装XC32 V1.44 B部分支持修补程序。
以上来自于百度翻译 以下为原文 v2.05 release requires the XC32 v1.44 B part support patch to be installed. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
501 浏览 0 评论
5808 浏览 9 评论
2350 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3543 浏览 3 评论
1155浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1119浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
887浏览 1评论
501浏览 0评论
/9
GMT+8, 2025-12-12 05:28 , Processed in 0.856151 second(s), Total 85, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
902
