扫一扫,分享给好友
我尝试使用Ortho的演示应用程序“CDCKCOMLPORTHORIONDION”,使用最新的和声和调整/重做它,用于MyPIC32 MK1024GPE开发板。我一直停留在一个点上,和谐配置器拒绝显示更多的一个实例来进行配置。我已经检查了最后的模板SytSysFig .h,它显示了:定义了UbxDeVice和StascSnS1,它应该是2。它应该是处理器的一些FTL文件,但我能找到的是基于模型的和声是一些& lt;MullMyNo.G..t;一个用于寄存器配置的文件,是一个二进制文件。Twitter SturySyfig.h对配置器没有帮助,因为这显然是它的输出文件…
以上来自于百度翻译 以下为原文 I tried to use hARMony's demo app "cdc_com_port_dual" with newest harmony and tweak/rework it for my PIC32MK1024GPE Development board. I've got stuck on a point where Harmony Configurator refuses to display more thatn one instance for configuration. I've checked the final template system_config.h and it shows: #define USB_DEVICE_INSTANCES_NUMBER 1 it should be 2. Where does iCOnfigurator take data from this template ? It should be some ftl file of the processor, but all I can find inside Harmony that is model based is some Tweaking system_config.h doesn't help with configurator as this is obviously its output file... |
2个回答
我还选择了这一部分,用于2 USB,以发现H2.05没有支持它。我打开了一张票,并通过当地的FAE支持,以得到一些想法时,它将得到支持。它不是在路线图和谐发展在那个时候。我还发现,PIC32 MK是拙劣的苏。在H2.05中使用了SPI/FS/STT25的一些错误和问题。在2.04中,您必须手动设置SPI6I/O.。
以上来自于百度翻译 以下为原文 I also selected this part for the 2 USB's to find out that H2.05 has no support for it. I opened a ticket on this and went though local FAE support to get some idea when it would be supported. Its was not on the road map for Harmony development at that time. I also found that that PIC32MK is poorly supported in H2.05 with a number of errors and issues with SPI/FS/STT25. In 2.04 you have to manually set SPI6 I/O. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:38 , Processed in 5.724609 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2357
