你好
我是FPGA新手并使用ise进行编程。 我已经购买了一个spartan-3E入门套件,该盒子涉及ise9.1 DVD。我成功获得了该软件的许可并将其设置为。但是当我尝试检查我的程序的sysntax以下错误诅咒时.. 已启动:“检查计数器语法”.ERROR:Xst:1531 - 此评估软件的评估期已过期。 根据评估协议的指导原则,该指南随评估CD一起发送给您,此软件将不再运行。 在您完成对Xilinx解决方案的评估时,我们非常乐意为您提供帮助。 您当地的现场应用工程师或销售人员可以回答任何问题或协助您购买年度软件许可证。 您也可以通过eval@xilinx.com直接联系Xilinx。感谢您评估Xilinx解决方案。 感谢您对Xilinx的关注,我们期待着您的信心和业务。 现在我该怎么办? Xilinx给我新的许可吗? 我不想使用ise13 becuse ise DVD pack我可以买,所有都在这里破解! 我无法达到一个可靠的。 以上来自于谷歌翻译 以下为原文 hello i'm new to FPGAs and programming using ise. i have purchased a spartan-3E starter kit and the box involved ise9.1 DVD .I successfuly licensed the software and instaled it.but when i try to check my program's sysntax the following error accurs .. Started : "Check Syntax for counter". ERROR:Xst:1531 - The evaluation period for this evaluation software has expired. Per the guidelines of the Evaluation Agreement, which was shipped to you along with the Evaluation CDs, this software will no longer operate. We are eager to assist you as you conclude your evaluation of the Xilinx solution. Your local Field Applications Engineer or salesperson is available to answer any questions or to assist you in the purchase of an annual software license. You may also contact Xilinx directly at eval@xilinx.com Thank you for evaluating the Xilinx solution. We appreciate your interest in Xilinx and we look forward to earning your confidence and your business. now what do I have to do? do the Xilinx gives me new license? I don't want to use ise13 becuse ise DVD packs that i can buy ,all are cracked here! i can't reach a sutable one. |
4个回答
pourya_alinezhad写道:
我不想使用ise13 becuse ise DVD pack我可以买,所有都在这里破解! 但你做到了! ;) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 pourya_alinezhad wrote: But you did! ;) View solution in original post |
pourya_alinezhad写道:
我不想使用ise13 becuse ise DVD pack我可以买,所有都在这里破解! 但你做到了! ;) 以上来自于谷歌翻译 以下为原文 pourya_alinezhad wrote: But you did! ;) |
pourya_alinezhad写道:
我不想使用ise13 becuse ise DVD pack我可以买,所有都在这里破解! 最好打电话给有关人员进一步调查。 董事会将讨论技术问题/查询,而不是讨论这些废话! 我希望听众理解并遵守规则如果我没有错! 以上来自于谷歌翻译 以下为原文 pourya_alinezhad wrote: I don't want to use ise13 becuse ise DVD packs that i can buy ,all are cracked here! Better to call concerned persons for further investigation. The board is to discuss technical issues/queries and not to such crap things! I hope listener understands and follow the rules If I am not wrong! |
对。
您可以通过Google获取信息并找到解决方案。 祝你好运! __________________________________ 信用卡和支票处理公司 以上来自于谷歌翻译 以下为原文 Right. You can Google th einformation and find the solution for it. Good Luck! __________________________________ credit card and check processing company |
只有小组成员才能发言,加入小组>>
3138 浏览 7 评论
3433 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2895 浏览 9 评论
4094 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3079 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1356浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1194浏览 1评论
/9
GMT+8, 2025-12-10 12:36 , Processed in 0.593250 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2736
