电子发烧友论坛|
我试图通过matlab控制我的示波器以自动化数据收集,但是在设置VISA TCP / IP连接时遇到了问题。
我已将我的示波器和计算机连接到专用网络,并在同一子网掩码上将它们设置为静态IP。 我已经通过ping我的计算机和范围来确认连接,反之亦然。 我也可以从我的电脑上调出范围的Web控件。 所以我有一个经过验证的功能网络连接。 但是,当我尝试使用Agilent Connection Expert连接到示波器时,我完全失败了。 打开程序时未确定范围,因此我尝试在TCP / IP接口下添加新仪器。 此处的自动检测功能也失败了。 所以我尝试使用其静态IP地址手动添加范围,并再次失败。 由于我的网络连接工作,问题出在我的计算机或范围本身,但我完全不知道要检查或更改的设置。 请有人帮我指点正确的方向吗? 谢谢! 以上来自于谷歌翻译 以下为原文 I am trying to control my oscilliscope through matlab in order to automate data collection, but am having issue setting up the VISA TCP/IP connection. I have connected my scope and computer on a private network and set them both up with static IP's on the same subnet mask. I have confirmed the connection by pinging both from my computer to the scope and the reverse. I am also able to pull up web control for the scope from my computer. So I have a verified functional network connection. However, when I attempt to connect to the scope using Agilent Connection Expert I am completely unsuccessful. The scope is not identified when I open the program so I attempted to add a new instrument under the TCP/IP interface. The auto-detect feature here also failed. So I attempted to add the scope manually using its static IP address, and once again it has failed. Since my network connection works the problem lies either on my computer or the scope itself, but I am completely at a loss as to what settings to check or change. Can someone please help point me in the right direction? Thanks! |
1个回答
这可能是防火墙问题。
您没有说出您在PC上运行的任何版本的任何版本,但无论如何都要尝试完全关闭防火墙。 请注意,此范围大约在7年前停止,现在已不再适用。 获得更完整的答案将是随意的,并依赖于已经存在一段时间的个人的回忆。 人 以上来自于谷歌翻译 以下为原文 It's probably a firewall issue. You don't say what version of anything you are running on your PC, but in any case try completely turning off the firewall. Note that this scope was discontinued about 7 years ago, and is now out of support life. Getting more complete answers will be haphazard, and rely on the memories of individual people who have been around for a while. Al |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 04:42 , Processed in 3.375668 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1372
