电子发烧友论坛|
我发现很多人遇到这个问题,但他们都没有解决我的问题
一个星期前,我的计算机与英特尔的高清显卡驱动程序工作得很好,但后来我有一个窗口,所以我不得不格式化硬盘驱动器和运行新的Windows 10安装.. 这是当这个问题突然出现时,我安装了Windows Pro x64 1803,所有其他驱动程序都安装得很完美,但是当我尝试安装集成显卡驱动程序时..屏幕变黑的一半,所以我发现我的自我重新启动了系统 当我没有安装显卡时,这是我累了的修复: 1 - 更新了我的MSI B250M Pro-VD MoBo BIOS 2 - 启用UEFI启动 3 - 当然尝试了不同版本的驱动程序,包括MoBo CD附带的驱动程序 4 - 尝试在屏幕关闭时安装驱动程序(认为它可能是显示器) 和其他一些小事...... 我的电脑: 微星B250M Pro-VD,奔腾G4560 3.5GH,4GB DRR4 TeamGroup 2400Mhz,400W Havit PSU和旧的WD 320 GB硬盘 (编辑)我的PSU有一个用于CPU的4针连接器,但MoBo最多支持8个引脚 有人可以帮助我,谢谢 PS:我希望它不是硬件问题,因为我无法承受另一个CPU DxDiag.txt.zip 12.0 K. 以上来自于谷歌翻译 以下为原文 I v found many people with this problem but none of them had a fix to mine a week ago my computer was workin fine with intel's HD graphics card driverbut then I had an isue with windows so I had to format the HDD and run a new installation of windows 10.. this is when this problem popped up, I installed windows Pro x64 1803, all others drivers were installed perfectly but when I try to install the integrated graphics card driver .. half way the screen goes black, so I found my self hard rebooting the sytem and when I do the graphics card is not installed, this is the fixes I tired: 1 - Updated my MSI B250M Pro-VD MoBo BIOS 2 - Enabled UEFI boot 3 - ofcourse tried different versions of the driver including the one that came with MoBo CD 4 - tried to install the driver while the screen was plugged off ( thought it might be the monitor) and some other minor things.. My computer: MSI B250M Pro-VD, Pentium G4560 3.5GH, 4GB DRR4 TeamGroup 2400Mhz, 400W Havit PSU and an old WD 320 GB HDD (Edit) My PSU havea 4-pin-connecter for the CPU but the MoBo support up to 8 pins Can Some one Help me Please, and Thank you PS: I hope its not a hardware problem cuz I cant afford another CPU
3个回答
首先,一些方面评论:
使用您拥有的CPU,具有最大功率和仅有4针CPU连接器的PSU即可。 但是,请注意以下几点:在短期内,我建议您安装一个4针到8针的适配器(如下所示:Akasa AK-CBPW10-15BKCâbleadigateuralimentation ATX 4 broches vers 8 broches:Amazon。 fr)使12V电源更均匀地分布在CPU插座电源引脚上。从长远来看,如果/当您决定升级处理器时,我建议您升级到符合ATX12V标准(或符合EPS12V标准) PSU支持8针(或4 + 4针)CPU电源连接器。当您启用UEFI启动时,您是否还记得在Windows安装期间删除HDD上的所有分区? 只有删除所有分区才会安装所需的GPT分区表,以便进行正确的UEFI启动。 如果没有,您实际上可能无法在UEFI模式下启动。 检查是否是这种情况。 不幸的是,如果你是,你唯一能做的就是重新开始并重新安装Windows。 现在,对你的问题。 我总是建议您首先下载并安装由您的主板制造商(在本例中为MSI)网站提供的所有驱动程序的当前版本。 随主板提供的CD / DVD上的驱动程序版本通常过时而无用。 因此,我不建议您完全使用此CD。 作为一个起点,我建议您进行以下操作: 使用此PC或另一台PC,从MSI的站点下载最新版本的Intel HD Graphics驱动程序包,并将其存储在USB闪存盘上。将PC与Internet完全断开并保持断开连接,直到稍后在这些说明中重新连接它为止 。以安全模式打开PC。卸载您(或Windows Update)以前安装的任何现有版本的Intel HD Graphics驱动程序。 如果卸载步骤要求重新启动 - 但请记住以安全模式重新启动。重复步骤4,直到卸载所有英特尔版本的驱动程序并且系统使用Microsoft通用图形驱动程序(使用设备管理器确定正在运行的内容) )。安装先前下载的驱动程序版本。 如果卸载步骤要求,请重新启动。如果此时一切正常,请以正常模式重新启动(即退出安全模式)。将PC重新连接到互联网,然后依次单击“开始”,“设置”,“更新”和“更新”。 安全然后检查更新。 安装任何可用的更新。 重新启动时,该工具会告诉你to.Repeat第8步,直到最后,如果说有在这一点上做了不更updates.You're - 但对我来说,下一步:(再次使用设备管理器)检查英特尔的什么版本 安装了HD Graphics驱动程序并告诉我。 希望这可以帮助, 内容S 以上来自于谷歌翻译 以下为原文 First of all, some side comments:
Now, to your issue. I always recommend that you start by downloading and installing the current versions of all drivers that are provided by your board manufacturer's (MSI, in this case) web site. The versions of the drivers on the CD/DVD provided with your motherboard are usually so out of date as to be useless. I thus do not recommend that you use this CD at all. As a starting point, I suggest that you to the following:
Hope this helps, ...S |
tianyou15 发表于 2018-11-23 06:42 谢谢N.Scott.Pearson的帮助,我想它可能是分区,因为当我安装Windows时我得到了一个屏幕,我被要求选择安装Windows 10,所以我甚至可能将我的硬盘改为 SSD或者至少是一个新的,因为我现在的HDD属于我的旧PC,除此之外我会保留你所有的推荐和指导,因为它不是引起问题的分区...... 再次感谢您的时间和精力^^ 以上来自于谷歌翻译 以下为原文 Thank you N.Scott.Pearson for your help, I think it might be the partition because when I was installing windows I got a screen were I was asked to choose between to installation of windows 10, So I might even change my HDD to an SSD or at least a new one since my current HDD belongs to my old PC, other than that I ll keep all your recommendation and guidings under consideration incase it is not the partition thats causing the problem... And Thank you again for your time and effort ^^ |
wrfqwerty 发表于 2018-11-23 06:55 是的,如果你不删除所有现有的分区,它将保留你以前的任何分区表(在这样的二手硬盘上,这可能是传统的MBR分区表)。 要比以前更完整地说出来,您需要删除驱动器上的所有分区,然后告诉Windows安装到未使用/未分区的空间(现在应该包含整个驱动器)。 这可确保在UEFI模式下引导安装介质时,它将创建GPT分区表并完全支持UEFI引导。 它还将让Windows智能地选择如何在此驱动器上设置各种(系统和恢复)分区。 您可以进行三项主要更改,以提高系统的性能: 将内存量从4GB增加到8GB将产生显着差异。 我建议让第二个DIMM与你现有的DIMM相同。添加一个SSD - 即使是一个小的(128GB) - 并且在这个SSD上安装Windows 10将显着提高存储吞吐量(如果你选择小型(128GB)SSD,我 建议您将硬盘保留在系统中以存储(不常访问的)数据文件。根据主板的功能,您有三种选择可以实现此目的。这里以增加的性能顺序显示它们 (并且,不幸的是,增加成本订单):添加2.5英寸SATA III SSD。添加M.2 SATA III SSD。注意:项目#1和#2实际上提供相同级别的性能。我(仍然)推荐Item #1超过第1项,仅仅是因为它更干净地直接安装在主板上,并且不需要(单独)SATA电源和数据线。添加M.2 NVMe SSD。它们的性能是SATA III SSDs的3倍-4倍 到英特尔酷睿处理器(您的主板支持第6代和第7代英特尔酷睿i3,Co re i5和Core i7处理器)。 希望这可以帮助, 内容S 以上来自于谷歌翻译 以下为原文 Yea, if you don't delete all of the existing partitions, it is going to keep whatever partition table you had previously (which, on a used HDD like this, is likely a legacy MBR partition table). To say it more completely than I did previously, you need to delete all partitions on the drive and then tell Windows to install to the unused/unpartitioned space (which now should encompass the entire drive). This ensures that, if you booted the installation media in UEFI mode, it will create a GPT partition table and fully support UEFI boot. It will also let Windows intelligently choose how to set up the various (system and recovery) partitions on this drive. There are three major changes you could make that will improve your system's performance:
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 14:18 , Processed in 0.742757 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6148
