电子发烧友论坛|
嗨,
我有一个基于LIS344ALH的设计,其中噪声水平是一个非常敏感的参数,因为我需要测量mg范围内的信号。我想转向全数字组件,我正在寻找LIS2HH12。不幸的是,数据表中不包含任何有关噪声的信息。 我可以获得这些信息吗? 另一个问题:几乎所有加速度计的数据表都只以 g/ sqrt(Hz)为单位讨论机械噪声,但没有考虑到采集链而给出完整的噪声系数。 对于模拟加速度计,我是否可以考虑使用灵敏度将机械噪声值映射到电噪声值? 对于数字加速度计,Iconsider可以使用灵敏度将机械噪声值映射到数字噪声(LSB)值吗? 谢谢! #加速度计噪声 以上来自于谷歌翻译 以下为原文 Hi, I've a design based on LIS344ALH where the noise level is a very sensitive parameter since I need to measure signals in the mg range. I would like to move to a full digital component and I'm looking to the LIS2HH12. Unfortunetely, the datasheet doesn't contain any information about noise. Can I get this information? Another question: almost all accelerometer's datasheets talk about the mechanical noise only in �g/sqrt(Hz), but without giving a full noise figure taking into account the acquisition chain. For analog accelerometers, could I consider that I can map the value for mechanical noise to an electrical noise value using the sensitivity? For digital accelerometers, could Iconsider that I can map the value for mechanical noise to an digital noise (in LSB) value using the sensitivity? Thanks! #accelerometer-noise |
7个回答
在ODR = 100Hz,BW = 50Hz,FS时,LIS2HH12的典型加速度噪声值为1.4mg(RMS)
± 8.0克 数据表中的数字是整个链条的总噪声(MEMS元件,放大器,滤波器,ADC,))。 最好的祝福 米罗斯拉夫 以上来自于谷歌翻译 以下为原文 Typical value of acceleration noise for LIS2HH12 is 1.4mg(RMS) at ODR=100Hz, BW=50Hz, FS ± 8.0g The figure in datasheet is total noise of the whole chain (MEMS element, amplifiers, filters, ADC, …). Best regards Miroslav |
谢谢!
如果BW为50 Hz,则意味着噪声谱密度约为197μg/ sqrt(Hz)。 对于+ -8g范围,LSB为0.244mg,这意味着RMS噪声约为6 LSB。 对于我的应用,我将使用+ -2g范围,ODR 10 Hz和BW 50Hz。你有这个范围的RMS噪音值吗? 最好的祝福, 克里斯托夫 以上来自于谷歌翻译 以下为原文 Thanks! If the BW is 50 Hz, that means a noise spectral density of about 197µg/sqrt(Hz). For +-8g range, the LSB is 0.244mg, which means the RMS noise is about 6 LSBs. For my application, I'll use the +-2g range with ODR 10 Hz and BW 50Hz. Do you have a value for RMS noise for this range? Best Regards, Christophe |
不幸的是,我们无法在公共论坛上分享其他噪音值。
您可以联系您当地的销售代表。 但请注意,对于ODR = 10Hz,抗混叠滤波器固定为400Hz,因此可能存在混叠效应。 我建议使用ODR = 100 Hz,将模拟抗混叠滤波器截止频率设置为50Hz,然后使用数字低通滤波器。 最好的祝福 米罗斯拉夫 以上来自于谷歌翻译 以下为原文 Unfortunately, we can’t share other noise values on the public forum. You can contact your local sales representative. But please be aware that for ODR = 10Hz the anti-aliasing filter is fixed to 400Hz, so there could be aliasing effect. I would recommend to use ODR = 100 Hz, set the analog anti-aliasing filter cutoff frequency to 50Hz and then use digital low-pass filter. Best regards Miroslav |
Niclaes,你用它进行倾斜测量,对吧?
因为在尝试不同的模拟解决方案(LIS344,KXR94和ADXL203)之后,我正在使用这个加速度计。 目前我正在写驱动程序。 您对注册设置有什么建议吗? 如果您希望我能与您分享我在倾斜测量方面的经验。 谢谢 以上来自于谷歌翻译 以下为原文 Niclaes, are you using it for tilt measurement, right? Because I'm moving on this accelerometer right now after trying different analogic solution (LIS344, KXR94 and ADXL203). Currently I'm writing the driver. Do you have any suggestion about the register settings? If you wish I can share with you my experience on tilt measurement. Thanks |
你也可以考虑使用
http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/lis3dhh.html 这是非常低噪音的加速度计。 以上来自于谷歌翻译 以下为原文 You can also consider usage of http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/lis3dhh.html which is very low noise accelerometer. |
它似乎是一个全新的加速度计。不是吗?
没有提到 http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers.html?querycriteria=productId=SC444 以上来自于谷歌翻译 以下为原文 It seems to be a brand new accelerometer. Isn't it? Not mentioneted in http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers.html?querycriteria=productId=SC444 |
确实,这是一个非常新的设备。
有关您的信息,请注意LIS3DHH只有SPI接口。 以上来自于谷歌翻译 以下为原文 Indeed it is quite new device. For you information, please be aware that the LIS3DHH has only SPI interface. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
744浏览 5评论
/9
GMT+8, 2025-12-1 19:47 , Processed in 0.893818 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
421
