嗨,
我一直在使用版本11.2下的EDK / SDK工具而没有重大问题,但在升级到11.3后我只能打开SDK。 当我尝试通过桌面快捷方式或在xbash shell中打开EDK时,我收到一条消息,说它正在打开EDK GUI但随后退出。 Xps.exe将非常短暂地出现在Windows任务管理器中但随后消失,所以我不认为它在后台运行。 我在安装过程中遇到的一个错误是在最后,安装程序给出了一个弹出窗口,表示它无法写入C: Xilinx 11.1 common fileset.txt。 由于某种原因,该文件被设置为只读。 我解除了只读选择,然后在弹出窗口中单击“确定”。 我认为安装程序然后能够将一些最终信息写入文件,但也许它无法写出它应该写的一切? 只是一个想法。 文件内容是: Thu Dec 11 12:34:56 MDT 2008 :: version = 11.1Fri Oct 02 15:44:39 TZ 2009 :: summary = backup 11.1Fri Oct 02 15:44:39 TZ 2009 :: version = 11.3 我的配置是:Windows XP Professional Service Pack 2Xilinx 11.1,修补到11.2Any帮助将不胜感激。 我的许可证文件表明我也有xps的当前节点锁定许可证。谢谢 以上来自于谷歌翻译 以下为原文 Hi, I have been using the EDK/SDK tools under version 11.2 with no major issues, but after the upgrade to 11.3 I can only open SDK. When I try to open EDK, either through the desktop shortcut or in the xbash shell, I get a message that says it is opening the EDK GUI but then exits. Xps.exe will very briefly appear in the windows task manager but then disappears, so I don't think it is running in the background. One error I did get during the install was at the very end, the installer gave a popup that said it could not write into C:Xilinx11.1commonfileset.txt. For some reason that file was set as read only. I undid the read only selection and then clicked OK in the popup window. I think the installer was then able to write some final info into the file, but perhaps it could not write everything it was supposed to? Just a thought. The file contents are: Thu Dec 11 12:34:56 MDT 2008:: version=11.1 Fri Oct 02 15:44:39 TZ 2009:: summary=backup 11.1 Fri Oct 02 15:44:39 TZ 2009:: version=11.3 My configurations is: Windows XP Professional Service Pack 2 Xilinx 11.1, patched to 11.2 Any help will be appreciated. My license file indicates that I have a current node locked license for xps as well. Thanks |
6个回答
你能打开命令窗口并手动运行xps吗?
我的猜测是你会看到有关不正确的cygwin安装的消息。 如果是这种情况,您可以从命令窗口运行“xbash -cleanreg”,然后再次运行xps。 干杯, 吉姆 干杯,吉姆 以上来自于谷歌翻译 以下为原文 Can you open a command window and run xps mannually? My guess is that you would see messages about incorrect cygwin installation. If that's case, you can run "xbash -cleanreg" from the command window and then run xps again. Cheers, Jim Cheers, Jim |
吉姆,嗨,
谢谢回复。 我试图从xbash shell启动xps并获得消息,说它正在打开EDK GUI并返回到xbash提示符。 我认为它试图开始,因为我注意到它将在Windows任务管理器中出现,但只是退出awithout和视觉符号。 以上来自于谷歌翻译 以下为原文 Hi Jim, thanks for the reply. I have tried to launch xps from the xbash shell and get the message that says it is opening the EDK GUI and returns to the xbash prompt. I think it tries to start, as I noted that it will appear beiefly in the windows task manager, but just exits awithout and visual signs. |
更新:
我使用-cleanreg选项xbash,它只是重置注册表项,仍然没有打开edk。 我已经手动清理了注册表,但很高兴知道其他人可以使用这个选项。 以上来自于谷歌翻译 以下为原文 update: I used the -cleanreg option to xbash and it just resets the registry entries, still does not open edk. I had already cleand the registry manually, but it is good to know this option exists for others. |
在执行11.3更新后我遇到了同样的问题 - xps.exe启动但在GUI启动之前结束,无论是从命令行,Windows菜单还是从ISE调用。
我没有上面提到的安装错误问题。 SDK运行,但奇怪的是.vbs文件类型已更改为与记事本关联。 我不得不手动将其与Windows脚本主机重新关联。 奇怪的。 如果这是一个Cygwin兼容性问题,我不会感到惊讶,但清除缓存不起作用,也不会手动重新调整注册表。 我有一个类似的问题9.2与单独的Cygwin安装不好玩(见答案记录#23716和#24134)。 如果这是一个类似的问题,我没有时间搞清楚,我仍然需要使用9.2安装来维护旧项目。 我只是吹掉它并重新安装11.1-> 11.2。 如果有人在将来遇到解决方案,我很乐意听到它。 问候, 杰夫贝克特 高级电子工程师 火山公司 ***eckett@volcanocorp.com 以上来自于谷歌翻译 以下为原文 I experienced the same problem after doing the 11.3 update -- xps.exe starts but ends before its GUI comes up, either from the command line, the Windows menus, or invoked from ISE. I did not have the installation error problem mentioned above. The SDK runs, but oddly the .vbs file type had been changed to associate with notepad. I had to manually reassociate it with the Windows scripting host. Weird. I would not be surprised if this is a Cygwin compatibility problem, but clearing the cache doesn't work, nor does manually realigning the registry. I had a similar problem with 9.2 not playing nice with a separate Cygwin installation (see answer records #23716 and #24134). If this is a similar problem, I haven't the time to figure it out, and I still need to use the 9.2 installation for maintaining older projects. I'm just blowing it all away and reinstalling 11.1->11.2. If anyone comes across a solution in the future, I'd love to hear about it. Regards, Jeff Beckett Senior Electronics Engineer Volcano Corporation ***eckett@volcanocorp.com |
从11.1完全重新安装后,我现在正在11.3工作。
关闭。 以上来自于谷歌翻译 以下为原文 after complete reinstall from 11.1 I'm now working at 11.3. closed. |
blavoie,
你是否直接从11.2升级到11.3? 我还想问一下:您使用(或以前安装过)单独的Cygwin安装吗? 干杯, 杰夫 以上来自于谷歌翻译 以下为原文 blavoie, Did you do the upgrade to 11.3 directly from 11.2? I also meant to ask above: are you using (or had previously installed) a separate Cygwin installation? Cheers, Jeff |
只有小组成员才能发言,加入小组>>
2429 浏览 7 评论
2831 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2298 浏览 9 评论
3378 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2468 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1311浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
595浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
456浏览 1评论
2011浏览 0评论
737浏览 0评论
GMT+8, 2024-12-27 19:02 , Processed in 1.269184 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
