电子发烧友论坛|
嗨,我正在尝试使用excel表作为“配置表”,其中包含我在VEE中运行的程序的配置数据。
我已经让VEE程序打开相应的excel表并以2D数组的形式读取数据。 获取这些数据并使用单个数据填充许多不同“设置变量”的最简单方法是什么? (约20个不同的值,即:最小时间最大时间最小温度最大温度最小电压最大电压最小电流......等等)提前感谢您的帮助! 以上来自于谷歌翻译 以下为原文 Hi, I'm trying to use an excel sheet as a "configuration sheet" that has configuration data for the program I'm running in VEE. I already have the VEE program opening the appropriate excel sheet and reading the data in as a 2D array. What is the easiest way to take this array of data and populate many different "set variables" with individual data? (about 20 different values i.e.: min time max time min temp max temp min voltage max voltage min current ... etc.) Thanks in advance for your help! |
1个回答
嗨dbvee!
我今天试图做同样的事情,想出了这个。 我不知道如果它不断地将数据从数据库中拉出来它会执行得多快但是它确实更容易让它找到一个测试值的名称而不是试图将它指向一个可能改变的单元格位置 未来。 无需跟踪数据的位置! 所以看看,它可能对某些人来说太基本但似乎有效。 问候,库尔特 以上来自于谷歌翻译 以下为原文 Hi dbvee! I was trying to do the very same thing today and came up with this. I dont know how fast it will execute if it is constantly pulling data out of the database but it sure is a lot easier to have it look for a name of a test value instead of trying to pinpoint it to a cell location that may change in the future. No need to keep track of where that data is located! So take a look, it may be too basic for some but it seems to work. Regards, Kurt 附件
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 18:56 , Processed in 0.709001 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4835
