电子发烧友论坛|
你好,
我正在使用SPC5Studio和SPC560D30L3设备。到目前为止,我能够在没有任何错误/警告的情况下构建项目。最近我收到如下警告, 4:10:08 ****增量构建配置默认为项目XXX **** 做所有 编译osal_cfg.c 编译main.c 编译Global_Variables.c 编译XXX_Memory.c 编译XXX_Init.c 编译XXX_Uart.c 编译XXX_DataFlash.c 编译XXX_PWM.c 编译XXX_Watchdog.c 编译XXX_timer.c 编译XXX_Control.c 编译XXX_Process.c 编译XXX_Calibration.c 编译XXX_Indications.c 链接build / out.elf 警告:1。不兼容的部分标志c:/spc5studio/eclipse/plugins/com.st.tools.spc5.tools.hightec_1.0.0.201306281422/hightec/bin /../ lib / gcc / ppc-ht-eabi / 4.6 0.3 /../../../../ PPC-HT-EABI / LIB / VLE / NOF 的libc.a(lib_a-impure.o): 创建build / out.hex 输入部分'.sdata'='awsl' 输出部分'.data'='awl' 创建build / out.mot 创建build / out.bin 创建build / out.dmp 文本数据bss dec hex filename 50632 1208 7968 59808 e9a0 build / out.elf 完成 14:10:35构建完成(耗时26s.114ms) 这个警告有什么关系?我在哪里可以找到相关的信息和解决方案?有没有人经历过这个? 我们将非常感谢您的最早帮助。谢谢。 麦克风。 以上来自于谷歌翻译 以下为原文 Hello, I am using SPC5Studio with SPC560D30L3 device. Till date I was able to build the project without any error/warnings. Recently I am getting a warning as below, 4:10:08 **** Incremental Build of configuration Default for project XXX **** make all Compiling osal_cfg.c Compiling main.c Compiling Global_Variables.c Compiling XXX_Memory.c Compiling XXX_Init.c Compiling XXX_Uart.c Compiling XXX_DataFlash.c Compiling XXX_PWM.c Compiling XXX_Watchdog.c Compiling XXX_Timer.c Compiling XXX_Control.c Compiling XXX_Process.c Compiling XXX_Calibration.c Compiling XXX_Indications.c Linking build/out.elf warning: 1.incompatible section flags c:/spc5studio/eclipse/plugins/com.st.tools.spc5.tools.hightec_1.0.0.201306281422/hightec/bin/../lib/gcc/ppc-ht-eabi/4.6.3/../../../../ppc-ht-eabi/lib/vle/noflibc.a(lib_a-impure.o): Creating build/out.hex input section'.sdata' = 'awsl' output section '.data' ='awl' Creating build/out.mot Creating build/out.bin Creating build/out.dmp text data bss dec hex filename 50632 1208 7968 59808 e9a0 build/out.elf Done 14:10:35 Build Finished (took 26s.114ms) What is it related to this warning? Where can I find the information and solution for this? Has anyone experienced this? Your earliest help will be highly appreciated. Thanks. Mike. |
3个回答
伙计们,上面的帖子有什么帮助吗?虽然这是一个警告,它会在执行期间造成任何影响吗?
期待最早的回复。谢谢。 麦克风。 以上来自于谷歌翻译 以下为原文 Folks, Any help on above post? Though this is a warning, will it cause any impact during execution? Expecting earliest reply. Thanks. Mike. |
你好迈克,
定义“系统调用”的库和其他基本工具,如malloc,sprintf等。 使用来自Hightec编译器的libc库没有问题。 该库由工具链Hightec gcc powerpcvle编译 我们将尝试重新编译libc以删除此警告。 Anayway,使用这个库没有风险。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Mike , the library which defines the ``system calls'' and other basic facilities such as malloc, sprintf and so on .. There is no problem to use libc library coming from Hightec compiler. This library has been compiled by the toolchain Hightec gcc powerpcvle we will try to recompile the libc in order to remove this warning. Anayway, there is no risk to use this library. Best Regards Erwan |
感谢Erwan的快速回复。对于前进而言,这真的是一种纯粹的解脱。
再次感谢。 麦克风。 以上来自于谷歌翻译 以下为原文 Thanks Erwan for your quick reply. This is really a sheer relief for moving ahead. Thanks again. Mike. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1470 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1522 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3670 浏览 1 评论
3861 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2479 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
749浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
681浏览 5评论
728浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
971浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
776浏览 5评论
/9
GMT+8, 2025-12-13 00:55 , Processed in 1.374252 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
286
