电子发烧友论坛|
大家好!我想知道我是否需要MPLAB X IDE的许可证?我找不到任何说“免费”或“不”的东西。这是一个在大学的年度实习。也因为这一点,我不能仅仅阅读我的C30编译器“PIC30ELF C1.EXE:警告:一般许可证错误,请安装许可证”,因为我可能会在我的家…-所以我知道有一个“免费”版本的C30编译器。但我不知道,不能找到任何条目说究竟是什么区别。在这个实习中,学生们不会做太花哨的事情,所以问题是:我需要它吗?我可以在没有购买许可证的情况下使用它吗?我希望我没有在论坛上阅读任何文章,谢谢!罗宾
以上来自于百度翻译 以下为原文 Hello everyone! I would like to know if i need a License for MPLAB X IDE? I Cant find anything saying "its free" or "its not". It's for an annual internship at the university. Also because of this i can't just read over the warning of my C30 Compiler "pic30-elf-cc1.exe: warning: General License error, please install a license" as i may would do at my home... ;-) So I know that there is a "free"-version of the C30 Compiler. But I dont know and cant find any entry saying what exactly is the difference. At this internship the students don't do too fancy stuff, so the question is: Do i need it? And can I use it for an academic use without buying the license? I hope i didnt read over any entry here in the forum. Thanks in advance! Robin |
4个回答
MPLAB X是免费的!下载它并安装它,忙着开发你的产品,希望能使用几百万个微芯片组件!编译器都是免费的,不是免费的。有一个没有(或非常少)优化的免费版本。这将允许您开发和测试。您可以购买具有增强的优化的许可版本。但我不知道所有的细节。编辑:我要指出的是,大多数用户都在使用免费版本。最后,C30已经被“蔑视”了。看看XC16编译器,因为它是现代的等价物。
以上来自于百度翻译 以下为原文 MPLAB X is free! Download it and install it and get busy developing your product that hopefully uses several million Microchip components! :) The compilers are both free and not free. There is a free version that has no (or very minimal) optimizations. This will allow you to develop and test. You can buy a licensed version that has enhanced optimization. But I don't know the details of all that. Edit: I would point out that the majority of users are using the free version. :) Finally C30 has been "deprecated". Look to the XC16 compiler for it's modern day equivalent. |
您不需要MPLAB X IDE的许可证,您可以在Microchip网站免费下载最新版本。然而,在这种情况下,XC16编译器需要编译器的许可证。C30不再支持新设备。但有一个免费版本,没有代码优化,我认为这将是绰绰有余。
以上来自于百度翻译 以下为原文 You don't need a licence for MPLAB X IDE, you can download the latest for free at Microchip website. However you'll need a licence for the compiler in this case XC16 compiler. C30 is no longer supported for new devices. But there is a free version with no code optimization which I think will be more than enough for you |
非常感谢你们的优秀和快速反应的家伙!但我仍然有一个问题:C30编译器显示每次我运行代码警告,它告诉我买许可证。我能做什么来告诉他我不需要任何许可证?应该有可能不显示警告…再次感谢您的帮助
以上来自于百度翻译 以下为原文 Thank you very much for your good and fast response guys! But I still have one question: The C30 Compiler shows everytime I run the code a warning, which tells me to buy a license. What can I do to tell him that I dont need any license? It should be possible to not show that warning.. Thank you again for your help |
在BIN目录中使用包含的许可管理器(PIC30LM.EXE),带有以下开关:-IX= DDMYYYY:使演示最后继续到日期MM/DD/YYYY IU= XXX:使演示最后XXX DaySoor最终使其成为完整版本-UMTIXYY4ZZZ(其中XX=01-04,YY=01-53,ZZZZ= 000 01-99 99)或安装串行MTI030340303
以上来自于百度翻译 以下为原文 Use included license manager in Bin directory (pic30-lm.exe) with the following switches: -ix=DDMMYYYY : make demo last to date MM/DD/YYYY -iu=XXX : make demo last XXX days or finally make it full version -uMTIxxyy4zzzz (where xx=01-04, yy=01-53, zzzz=0001-9999) Or install with Serial MTI030340303 |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-1 22:32 , Processed in 0.568656 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3750
