嗨,
我必须安装旧的Xilinx版本,当用户是Users组的成员时,它似乎不能正常工作。 它在管理员模式下工作正常。 我应该向Users组提供哪些文件或注册表权限才能运行Xilinx? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I have to install that old Xilinx version and it don't seems to work fine when the user is member of the Users group. It works fine in administrator mode. Which file or registry rights should I give to the Users group to be able to run Xilinx fine ? Thanks. |
5个回答
您必须具有管理员权限才能在Windows上正确安装这些工具。
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 You must have administrators rights to properly install the tools on Windows. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
嗨,
我想我只是不表达正确的事情。 我安装了Xilinx但是现在,我尝试以用户身份运行软件(Project Navigator)。 我能够启动应用程序并能够打开一个项目。 当我右键单击项目并选择New source - Test Benchmark - 2 Next and Finish时,没有任何事情发生在用户身上。 如果我以管理员身份运行应用程序,则会打开一个新窗口(初始化时间)。 我是否必须在特定文件或目录或某些注册表项上为用户组指定一些特殊权限才能运行应用程序而没有任何问题? 我完全控制了Xilinx目录,没有任何改变。 还有其他建议吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I think I just don't express the right thing. I installed Xilinx but now, I try to run the software (Project Navigator) as a user. I am able to start the app and able to open a project. When I right click on the project and select New source - Test Benchmark - 2 Next and Finish, nothing happen as a user. If I run the app as an admin, a new window open (initialize timing). Do I have to specify some special rights to the user group on specific files or directory or on some registry keys to be able to run the app without any problem ? I gave full control on the Xilinx directory and nothing changed. Any other suggestions ? Thanks. |
我不确定,但我认为你需要执行/读/写权限以下内容:
- Xilinx安装目录 - TEMP环境变量指向的位置 - HKEY_LOCAL_MACHINE / SOFTWARE / Xilinx / Xilinx ISE 7注册表内容 以上来自于谷歌翻译 以下为原文 I don't know for sure but I think you need execute/read/write permission to the following: - The Xilinx install directory - The location pointed to by the TEMP environment variable - The HKEY_LOCAL_MACHINE/SOFTWARE/Xilinx/Xilinx ISE 7 registry content |
用户不应该需要Xilinx安装目录的写权限,但我同意TEMP目录。
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 A user shouldn't need write permission to the Xilinx install directory, but I would agree about the TEMP directory. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
嗨,
用户组在Xilinx文件夹上具有读/写/执行功能。 我对注册表项进行了完全控制,TEMP文件夹位于%USERPROFILE% Local Settings Temp下,因此默认情况下,用户可以完全控制该文件夹。 当我执行ise.exe并尝试我想做的事情时(如我之前的帖子中所指定的),没有任何反应,并且Initialize Timing窗口无法打开。 感谢任何其他解决方案。 以上来自于谷歌翻译 以下为原文 Hi, Users group have read/write/execute on the Xilinx folder. I gave Full control on the registry key and the TEMP folder is under %USERPROFILE%Local SettingsTemp so by default, the user have full control on that folder. When I execute ise.exe and try what I want to do (as specified in my previous post), nothing happen and the Initialize Timing window don't open. Thanks for any other solutions. |
只有小组成员才能发言,加入小组>>
2321 浏览 7 评论
2729 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2368 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
653浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
461浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
222浏览 1评论
668浏览 0评论
1860浏览 0评论
GMT+8, 2024-9-29 14:00 , Processed in 1.248228 second(s), Total 85, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
