电子发烧友论坛|
大家好,
我使用的是iNEMO和ST提供的AHRS算法。我注意到函数指针初始化存在问题。这些函数指针用于指向AHRS算法(其代码不由ST提供)。特别是,使用三条指令来执行此算法: 1)//初始化所有AHRS参数 iNEMO_AHRS_Init(& xSensorData,& xEulerAngles,& xQuat); 2)//更新 iNEMO_AHRS_Update(& xSensorData,& xEulerAngles,& xQuat); 3)//释放内存 iNEMO_AHRS_DeInit(& xSensorData,& xEulerAngles,& xQuat); 这些函数指针指向FLASH存储器的一部分,但是还需要RAM预留来分配算法使用的东西。实际上,必须使用以下说明: volatile uint8_t pcDummyAHRSReserved [AHRS_RESERVED_RAM_SIZE] @AHRS_RESERVED_RAM_START_ADDR; pcDummyAHRSReserved [0] = 0; 如ST示例程序中所指定的。但这不起作用,我想这是因为内存分配存在问题。谁能帮助我?我应该指定什么才能正确执行我的程序?先谢谢你! 以上来自于谷歌翻译 以下为原文 Hello everyone, I am using iNEMO with AHRS algorithm provided by ST. I have noticed that there is a problem about function pointers initialization. These function pointers are used to point the AHRS algorithm (whose code is not provided by ST). In particular, three instructions are used to execute this algorithm: 1) // Init the all AHRS parameters iNEMO_AHRS_Init(&xSensorData, &xEulerAngles, &xQuat); 2) //update iNEMO_AHRS_Update(&xSensorData, &xEulerAngles, &xQuat); 3) // Deallocate memory iNEMO_AHRS_DeInit(&xSensorData, &xEulerAngles, &xQuat); These function pointers are pointing to a part of FLASH memory, but RAM reservation is also required to allocate something used by the algorithm. In fact one has to use the following instructions: volatile uint8_t pcDummyAHRSReserved[AHRS_RESERVED_RAM_SIZE] @AHRS_RESERVED_RAM_START_ADDR; pcDummyAHRSReserved[0] = 0; as specified in an ST sample program. But this doesn't work, and I suppose this is beacuse there are problems with memory allocation. Could anyone help me? What should I specify to execute my program correctly? Thank you in advance! |
2个回答
嗨!您是否尝试过增加堆内存大小?
以上来自于谷歌翻译 以下为原文 Hi! Have yoy tried to increase the heap memory size? |
你好
我们有同样的问题。你解决了吗? 以上来自于谷歌翻译 以下为原文 Hello We have the same problem. Have you solved it. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1469 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1521 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3668 浏览 1 评论
3860 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2477 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
748浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
680浏览 5评论
727浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
968浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
771浏览 5评论
/9
GMT+8, 2025-12-12 03:43 , Processed in 0.740209 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1505
