电子发烧友论坛|
全部:有人可以告诉我N5230C的哪个SCPI用于图片中显示的内存跟踪。
我只想选择“内存跟踪”(Trace view Option)按钮。 但我不是SCPI,请帮我解决这个问题,谢谢 以上来自于谷歌翻译 以下为原文 All: Can someone tell me which SCPI of N5230C is for the Memory trace showing in the picture. I just want to select the “memory trace” (Trace view Option) button. But I do not the SCPI, Please help me fix this problem, thanks 附件
4个回答
亲爱的Dr_joel:非常感谢你给我一些帮助
以上来自于谷歌翻译 以下为原文 Dear Dr_joel: please give me some help thanks very much |
不幸的是,SCPI与GUI完全不匹配。 您正在寻找的命令被调用:DISP:WIND:TRAC:MEM - >此命令打开或关闭内存跟踪和DISP:WIND:TRAC:[STATe] - >此命令打开或关闭数据跟踪 一组SCPI命令显示如何设置跟踪并查看内存跟踪:SYST:FPR'清除所有跟踪和窗口DISP:WIND ON'创建窗口#1 CALC:PAR:DEF'myS11',S11'接下来的两行创建 一个S11测量,他们将其命名为“myS11”DISP:WIND:TRAC1:FEED'myS11'CALC:MATH:MEM'将跟踪副本存储为存储器DISP:WIND:TRAC1:MEM 1'打开存储器跟踪DISP :WIND:TRAC1 OFF'关闭数据跟踪 以上来自于谷歌翻译 以下为原文 Unfortunately, the SCPI doesn't match the GUI exactly. The commands that you are looking for are called: DISP:WIND:TRAC:MEM -> this command turns on or off the memory trace and DISP:WIND:TRAC:[STATe] -> this command turns on or off the data trace This set of SCPI commands shows how to setup a trace and view the memory trace: SYST:FPR 'clears all traces and windows DISP:WIND ON ' creates window #1 CALC:PAR:DEF 'myS11',S11 'The next two lines create an S11 measurement and they name it "myS11" DISP:WIND:TRAC1:FEED 'myS11' CALC:MATH:MEM ' Store off a copy of the trace as memory DISP:WIND:TRAC1:MEM 1 ' Turn on the memory trace DISP:WIND:TRAC1 OFF 'Turn off the data trace |
60user56 发表于 2018-11-14 13:28 如果我们使用TNUM或Calc:Par:Sel关联混淆一个类似的命令,那不是很好。 像“Calc:Par:Tnum Mem On”之类的东西 以上来自于谷歌翻译 以下为原文 wouldn't it be nice if we aliased a similar command using TNUM or Calc:Par:Sel association. Something like "Calc:Par:Tnum Mem On" |
实际上 - 您需要的是此命令“CALC:PAR:MEM [:STAT],因此您可以使用”calc:par:sel“或”calc:par:mnum“选择跟踪,然后您可以打开内存跟踪或 使用我上面提出的命令。 以上来自于谷歌翻译 以下为原文 Actually - what you need is this command "CALC:PAR:MEM[:STAT] so you would select the trace using "calc:par:sel" or "calc:par:mnum" and then you could turn the memory trace on or off using the command I proposed above. |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1843浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 17:26 , Processed in 0.954394 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2367
