电子发烧友论坛|
使用Intel Power Gadget for Mac时,它不会将数据记录到文件中。
(换句话说,无论我在哪里设置目的地,它都没有创建日志文件)没有明显指示何时创建文件? 当应用程序关闭但它没有。 以上来自于谷歌翻译 以下为原文 When using the Intel Power Gadget for Mac, it is not logging data to a file. (in other words its not creating a log file, no matter where i set the destination) There is no obviously indication of when the file would be created either? when the app closes but it doesn't. |
8个回答
您好Lovefire,感谢您通过我们的社区发布您的查询。让我们进一步调查,我们会在收到更多信息后立即与您联系。我希望这有帮助.Regards,Diego S.
以上来自于谷歌翻译 以下为原文 Hello Lovefire, Thank you for posting your inquiry through our communities. Let us investigate further into this, we will reach you back as soon as we have more information. I hope to this helps. Regards, Diego S. |
jerry1978 发表于 2018-11-13 09:30 您好Lovefire,感谢您的耐心等待。我已向您发送了私信,请您查看您的收件箱。我希望尽快收到您的来信.Regards,Diego S. 以上来自于谷歌翻译 以下为原文 Hello Lovefire, Thank you for your patience. I have sent you a private message, please take a look at your inbox. I hope to hear from you soon. Regards, Diego S. |
默认情况下不启用日志记录,请通过转到顶部菜单栏中的“日志记录”,然后选择“登录到文件”以切换日志记录开关,确保启用日志记录。
您将看到一条消息,指示已开始和停止日志记录。 以上来自于谷歌翻译 以下为原文 Logging is not enabled by default, please ensure you are enabling it by going to "Logging" in the top menu bar, and selecting "Log to File" to toggle logging on / off. You will see a message indicating logging has started and stopped. |
jerry1978 发表于 2018-11-13 09:57 在最近的更新3.4.5之前,当我使用3.4.3时它没有工作。 我也非常清楚它默认情况下未启用,需要用户交互才能启用。 我的观点是,如何创建日志会误导您必须通过再次单击它或在创建日志之前再次按CMD + L来关闭日志记录,这不直观; 因此,我建议帮助其他人指示。 以上来自于谷歌翻译 以下为原文 It wasnt working prior to the recent update 3.4.5, when I was using 3.4.3. I am also very aware its not enabled by default and requires user interaction to enable. My point was it was misleading on how to create the log in that you have to actually turn off logging by clicking it again or pressing CMD+L again before a log is created, its not intuitive; hence my suggestion to help others with instructions. |
jerry1978 发表于 2018-11-13 09:30 你好迭戈, 由于Logging再次运行,我遇到了另一个问题,即“CSV文件”,这是在记录时创建的。 在MacOS上我可以通过预览快速查看它,通过选择文件并在加载空格键时看到它在表格中。 大。 但是当它被macOS中的任何默认应用程序打开时,表格就会消失,如果放入应用程序支持表格,它就不会正确放置信息。 这让我相信在创建时可能存在问题。 不确定。 以为id问。 我真的只是希望能够打开它,并且有一张表格,其中包含正确位置的所有信息。 以上来自于谷歌翻译 以下为原文 Hello Diego, Since getting the Logging to work again, I have run into another issue with the "CSV File" this is created when logging. On MacOS I can QuickView it via Preview by selecting the file and pressing the space bar when it loads you see its in tables. great. but when its opened by any default app in macOS the tables is gone and if placed into a app the supports tables it doesn't place the information correctly. which leads me to believe there might be an issue when its being created. no sure. thought id ask. I really just want to be able to open it and have there be a table with all the information in the correct spots. |
cd340823 发表于 2018-11-13 10:20 你能提供一个屏幕截图来显示你所描述的问题吗? 以上来自于谷歌翻译 以下为原文 Can you provide a screen shot showing the issue you're describing? |
当然: 有3个附件: 一个是通过预览应用程序使用QuickView时的外观(使用表格看起来很正常) 另外两个是textEdit(默认应用程序)和Numbers(我下载了以查看是否有所不同,因为数字将3列放在一个中) 屏幕截图2018-10-02 at 6.22.32 PM.png 988.9 K. 数字不正确display.png 3.0 MB 正确显示2018-10-02 at 5.42.50 PM.png 3.3 MB 以上来自于谷歌翻译 以下为原文 Of course: There are 3 attachments: one is how it looks when using QuickView via Preview App (looks normal with a table) the other two are textEdit (default app) and Numbers (which I downloaded to see if that made a difference it did not since numbers put 3 columns in one)
我在Numbers中复制了这个问题。 这是Numbers默认情况下解析CSV文件的方式的问题。 现在,您可以通过调整导入设置来使用逗号分隔符来解决此问题。 我将在下一次更新中对日志格式进行调整,以便在Numbers中解决此问题。 以上来自于谷歌翻译 以下为原文 I have reproduced this issue in Numbers. This is an issue with how Numbers parses CSV files by default. For now you can work around this by adjusting the import settings to use a comma delimiter. I will make an adjustment to the log format in the next update which will resolve this issue in Numbers. |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-14 04:35 , Processed in 1.654346 second(s), Total 90, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1661
