电子发烧友论坛|
当我收到这样的警告时:
警告:[BD 41-1731]连接引脚之间的类型不匹配:/ verandfreqcount_0 / onepps(undef)和/ onepps(clk) 在verandfreqcount_0 / onepps上设置类型的最佳方法是什么?使用命令行和createandpackage IP工具的示例? 以上来自于谷歌翻译 以下为原文 when I get a warning like this: WARNING: [BD 41-1731] Type mismatch between connected pins: /verandfreqcount_0/onepps(undef) and /onepps(clk) What's the best way to set the type on verandfreqcount_0/onepps? Example with both the command line and the createandpackage IP tool? |
5个回答
这是它在命令行上的ipx版本,但我想知道是否可能在事后或是否有其他人。
ipx :: infer_bus_interface onepps xilinx.com:signal:clock_rtl:1.0 [ipx :: current_core] ipx :: infer_bus_interface highspeedclk xilinx.com:signal:clock_rtl:1.0 [ipx :: current_core] 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 This is the ipx version of it on the command line, but I was wondering if it's possible after the fact or if there were others. ipx::infer_bus_interface onepps xilinx.com:signal:clock_rtl:1.0 [ipx::current_core] ipx::infer_bus_interface highspeedclk xilinx.com:signal:clock_rtl:1.0 [ipx::current_core] View solution in original post |
嗨@petersk,
最好的方法是打包IP。 在端口定义中,只需将类型更改为clk。 问候, 弗洛朗 FlorentProduct应用工程师 - Xilinx技术支持EMEA ------------------------------------------ -------------------------------------------------- ----------------------------不要忘记回复,kudo,并接受作为解决方案。 以上来自于谷歌翻译 以下为原文 Hi @petersk, The best way is when you package the IP. In the port definition, just change the type to clk. Regards, Florent Florent Product Application Engineer - Xilinx Technical Support EMEA ------------------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. |
ipx :: infer_bus_interface onepps xilinx.com:signal:clock_rtl:1.0 [ipx :: current_core] ipx :: infer_bus_interface highspeedclk xilinx.com:signal:clock_rtl:1.0 [ipx :: current_core] 以上来自于谷歌翻译 以下为原文 This is the ipx version of it on the command line, but I was wondering if it's possible after the fact or if there were others. ipx::infer_bus_interface onepps xilinx.com:signal:clock_rtl:1.0 [ipx::current_core] ipx::infer_bus_interface highspeedclk xilinx.com:signal:clock_rtl:1.0 [ipx::current_core] |
你会在哪里将端口定义更改为clk?
以上来自于谷歌翻译 以下为原文 Where would you change the port definition to clk? |
对不起,它已经在这个帖子中,我错过了它。
只需右键单击端口并“自动推断”... 以上来自于谷歌翻译 以下为原文 Sorry, it was already in this thread and I missed it. Simply right click on the port and "Auto infer"... |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1363浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1201浏览 1评论
/9
GMT+8, 2025-12-14 22:08 , Processed in 1.021605 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2095
