电子发烧友论坛|
我有一个输入“data_in”,“rst”和“clk”的函数。
我想要做的是我想修复所有这些路线。 按照UG903中的示例,我首先尝试修复“data_in”。 但我有下面的错误。 错误:[Designutils 20-949]在net data_in上找不到驱动程序。 .xdc看起来像 set_property BEL C5LUT [get_cells r5_i_1] set_property BEL G6LUT [get_cells r3_i_2] set_property BEL H6LUT [get_cells r8_i_1] set_property BEL C6LUT [get_cells r4_i_1] set_property BEL H6LUT [get_cells data_out_INST_0] set_property BEL B5LUT [get_cells r7_i_1] set_property LOC SLICE_X53Y443 [get_cells r8_i_1] set_property LOC SLICE_X53Y442 [get_cells r4_i_1] set_property LOC SLICE_X53Y443 [get_cells r3_i_2] set_property LOC SLICE_X53Y442 [get_cells r7_i_1] set_property LOC SLICE_X53Y442 [get_cells r5_i_1] set_property LOC SLICE_X53Y442 [get_cells data_out_INST_0] set_property LOCK_PINS {I0:A3} [get_cells r4_i_1] set_property LOCK_PINS {I0: A3} [get_cells r5_i_1] set_property LOCK_PINS {I2:A1} [get_cells r8_i_1] set_property LOCK_PINS {I4:A4} [get_cells r7_i_1] set_property LOCK_PINS {I5:A4} [get_cells data_out_INST_0] set_property LOCK_PINS {I5:A5} [get_cells r3_i_2] set_property FIXED_ROUTE {{{EE1_E_BEG0 INT_NODE_IMUX_62_INT_OUT1 IMUX_W1} INT_NODE_SDQ_49_INT_OUT1 {NN1_W_BEG1 INT_NODE_IMUX_34_INT_OUT1 BOUNCE_W_2_FT1 INT_NODE_IMUX_58_INT_OUT1 IMUX_W38} SS1_W_BEG1 {INT_NODE_IMUX_63_INT_OUT0 {BYPASS_W3 INT_NODE_IMUX_44_INT_OUT0 IMUX_W37} IMUX_W23} INT_NODE_IMUX_62_INT_OUT1 IMUX_W16}} [get_nets DATA_IN] 有什么建议吗? 以上来自于谷歌翻译 以下为原文 I have a function that has an input of "data_in", "rst", and "clk". What I want to do is that I want to fix all these routes. Following the example in UG903, I am trying to fix the "data_in" first. But I've got the error below. ERROR: [Designutils 20-949] No driver found on net data_in. The .xdc looks like set_property BEL C5LUT [get_cells r5_i_1] set_property BEL G6LUT [get_cells r3_i_2] set_property BEL H6LUT [get_cells r8_i_1] set_property BEL C6LUT [get_cells r4_i_1] set_property BEL H6LUT [get_cells data_out_INST_0] set_property BEL B5LUT [get_cells r7_i_1] set_property LOC SLICE_X53Y443 [get_cells r8_i_1] set_property LOC SLICE_X53Y442 [get_cells r4_i_1] set_property LOC SLICE_X53Y443 [get_cells r3_i_2] set_property LOC SLICE_X53Y442 [get_cells r7_i_1] set_property LOC SLICE_X53Y442 [get_cells r5_i_1] set_property LOC SLICE_X53Y442 [get_cells data_out_INST_0] set_property LOCK_PINS {I0:A3} [get_cells r4_i_1] set_property LOCK_PINS {I0:A3} [get_cells r5_i_1] set_property LOCK_PINS {I2:A1} [get_cells r8_i_1] set_property LOCK_PINS {I4:A4} [get_cells r7_i_1] set_property LOCK_PINS {I5:A4} [get_cells data_out_INST_0] set_property LOCK_PINS {I5:A5} [get_cells r3_i_2] set_property FIXED_ROUTE { { EE1_E_BEG0 { INT_NODE_IMUX_62_INT_OUT1 IMUX_W1 } INT_NODE_SDQ_49_INT_OUT1 { NN1_W_BEG1 INT_NODE_IMUX_34_INT_OUT1 BOUNCE_W_2_FT1 INT_NODE_IMUX_58_INT_OUT1 IMUX_W38 } SS1_W_BEG1 { INT_NODE_IMUX_63_INT_OUT0 { BYPASS_W3 INT_NODE_IMUX_44_INT_OUT0 IMUX_W37 } IMUX_W23 } INT_NODE_IMUX_62_INT_OUT1 IMUX_W16 } } [get_nets data_in] Any suggestion? |
2个回答
@ moon5756,
你能告诉我们错误信息中提到的data_in net的原理图吗? 命令“get_property ROUTE [get_netsdata_in]”的结果是什么 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @moon5756, Can you show us the schematic of data_in net mentioned in error message? What is the result of command "get_property ROUTE [get_nets data_in]" --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@syedz谢谢你的回复!
我有 get_property ROUTE [get_nets data_in] {} 这是什么意思? 因此,为了进一步解释,我想要实现这一目标的主要原因是我希望删除OOC实现中的“顶级实现”过程:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug946-vivado- 分层设计tutorial.pdf。 route_design在顶层有“顶级实现”,但我相信这个过程在理论上是不必要的。 通过在pblock边界上手动路由网络,我们应该可以跳过此过程。 谢谢! 以上来自于谷歌翻译 以下为原文 @syedz Thanks for the reply! I've got get_property ROUTE [get_nets data_in] {} what does it mean? So, to explain further, the main reason I want to achieve this is that I want to remove "top implementation" process in OOC implementation in https://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug946-vivado-hierarchical-design-tutorial.pdf. There is "top implementation" to route_design on the top-level, but I believe this process is theoretically unnecessary. By manually routing the nets on the pblock boundary, we should be able to skip this process. Thanks! |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 02:32 , Processed in 0.687726 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
446
