你好
Q1)关于BMAX功率,它在数据表的第14页中被描述,但是我们理解有必要为每个连接的“设备”设置最大功率值吗? 如果没有,请告诉我详情。 2-1)默认值被描述为“32 H(100毫安)”,但请告诉我原因。 Q2-2)当HX2VL用自功率供电时,有可能将BMAX功率描述符信息自身改变为FAH(500毫安)吗?如果是,有可能直接改变EEPROM的BMAX功率值吗? 最好的问候 阿莱 以上来自于百度翻译 以下为原文 Hello Q1)Regarding the bMax-power, it is described on page 14 of the datasheet, but we are understanding that it is necessary to set the Maximum Power value for each connected "devices"? If no, please tell me the details. Q2-1) The default value is described as "32h(100 mA)", but please tell me the reason. Q2-2)When powering HX2VL with self power, is it possible to change the bMax-power descriptor information by themselves to FAh(500 mA)?If yes, is it possible to change the bMax-power value of EEPROM directly? Best Regards Arai |
1个回答
嗨,Arai san,
Q1)不可能将最大功率值设置到每个连接的“设备”。 取而代之的是,每个设备都有它自己的最大功率值,它将通过它的描述符向主机显示。 Q2-1)默认值指示为100mA,用于自供电集线器。 对于总线供电的集线器,它需要设置为500毫安(FAH),以适应每个下游设备100mA(4×100mA)+轮毂功耗(100mA)。 Q2-2)如果应用需要在总线供电和自供电模式之间切换,建议将最大功率值设置为500毫安。 可以通过外部的EEPROM通过Bulter实用工具来改变最大功率值。要使用Bulter实用程序,集线器需要绑定到供应商驱动程序。 最好的问候, 高山弘 以上来自于百度翻译 以下为原文 Hi Arai-san, Q1) It is NOT possible to set the MaxPower value to each connected "device". Instead, each device will have its own MaxPower value which will be indicated to the host through its descriptors. Q2-1) The default value is indicated as 100mA which is intended for Self-Powered Hub. For Bus-Powered Hub, it needs to be set as 500mA (FAh) to accommodate 100mA for each downstream device (4 x 100mA) + Hub power consumption (100mA). Q2-2) It is recommended to set MaxPower value to 500mA if the application requires switching between Bus-Powered and Self-Powered modes. It is possible to change the MaxPower value with the help of external EEPROM through Blaster Utility. To use Blaster utility, Hub needs to be bound to Vendor driver. Best regards, Hirotaka Takayama |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 09:01 , Processed in 0.803521 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2107
