电子发烧友论坛|
嗨,
我正在尝试使用LUT生成时钟,我在生成比特流时遇到错误。 然后我已经给出了以下约束来覆盖循环接收条件,但工具说xdc约束文件中不支持该命令。 为什么???? 什么是?????? “set_property ALLOW_COMBINATORIAL_LOOPS TRUE [net_nets”。 以上来自于谷歌翻译 以下为原文 Hi, i'm trying to generate the clocks using LUT's, i'm getting error while generating the bit stream. then i have given the below constraints to over come the loop rece condition but tool saying the command is not supported in the xdc constraint file. why???? what is exactly "set_property ALLOW_COMBINATORIAL_LOOPS TRUE [net_nets |
5个回答
@yatish,
检查这个帖子: https://forums.xilinx.com/t5/Implementation/DRC-23-20-Rule-Violation-LUTLP-1/td-p/674253 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @yatish, Check this thread: https://forums.xilinx.com/t5/Implementation/DRC-23-20-Rule-Violation-LUTLP-1/td-p/674253 --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------View solution in original post |
xdc约束文件中不支持命令'net_nets'。
工具正在发出此警告 以上来自于谷歌翻译 以下为原文 Command 'net_nets' is not supported in the xdc constraint file. tool is giving this warning |
@yatish
你可以试试get_nets吗? 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @yatish Can you try with get_nets instead? Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
@yatish,
检查这个帖子: https://forums.xilinx.com/t5/Implementation/DRC-23-20-Rule-Violation-LUTLP-1/td-p/674253 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @yatish, Check this thread: https://forums.xilinx.com/t5/Implementation/DRC-23-20-Rule-Violation-LUTLP-1/td-p/674253 --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 11:09 , Processed in 0.895794 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8419
