你好!
关于FRAM存储器的可靠性和需要考虑什么样的软件,我有一些问题。 在写操作期间电源故障的影响是什么?这会影响被更新的字节,使其处于未知和潜在的易失状态吗?这会影响整排吗? 读/写干扰F RAM的问题吗?(按顺序排列)? 我搜索了知识库和应用笔记,但是找不到关于这个主题的任何信息。有没有柏树文献描述这一点? 当做 米卡尔 以上来自于百度翻译 以下为原文 Hi! I have some questions regarding the reliability of F-RAM memories and what software needs to take into consideration. What is the effect of power failure during a write operation? Will this affect the byte being updated, leaving it in an unknown and potentially volatile state? Can this affect the whole row? Is read/write disturb an issue on F-RAM? (On a row basis?) I searched through the knowledge base and the application notes but could not find any information on the topic. Is there any Cypress documentation describing this? Regards Mikael |
3个回答
嗨,Mikael,
如果在写入操作的中间丢失了功率,则只写入最后完成的字节。不完整的字节将不会被更新。FRAM在一个字节的数据被锁定之后更新存储器。你可以在写操作的FRAM数据表中发现这一点。 谢谢, 普拉迪普塔 以上来自于百度翻译 以下为原文 Hi Mikael, If the power is lost in the middle of the write operation, only the last completed byte will be written. The incomplete byte will not be updated. The FRAM updates the memory after a byte of data has been clocked in. You can find this documented in the FRAM datasheets under write operation. Thanks, Pradipta. |
WHR197 发表于 2018-11-2 15:22 你好! 是的,我在数据表中看到过。但我没有发现任何关于电源故障的潜在副作用的陈述,例如减少数据保留。 例如,在NAND上,如果在写一个页面时电源故障,页面可能会成为完全的垃圾,或者看起来是正确的,但是遭受可怕的坏数据保留(您可能会第一次读取有效数据,但随后的读取在恢复后损坏)。 谢谢 米卡尔 以上来自于百度翻译 以下为原文 Hi! Yes, I have seen that in the datasheet. But I did not find any statements regarding any potential side-effects of power failure, such as reduced data retention. For example on NAND, if power fail while writing a page, the page might end up as complete garbage or it could look correct but suffer from horrendously bad data retention (you might read back valid data the first time, but subsequent reads are corrupted beyond recovery). Thanks Mikael |
60user82 发表于 2018-11-2 15:38 嗨,Mikael, 不会有电源故障(如减少数据保持等)对FRAM的潜在副作用。 谢谢, 普拉迪普塔 以上来自于百度翻译 以下为原文 Hi Mikael, There will be no potential side effects of power failure (like reduced data retention etc) on FRAMs Thanks, Pradipta. |
只有小组成员才能发言,加入小组>>
742个成员聚集在这个小组
加入小组2012 浏览 1 评论
1773 浏览 1 评论
3561 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1705 浏览 6 评论
1473 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
350浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
250浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
364浏览 2评论
303浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
503浏览 2评论
GMT+8, 2024-9-29 20:16 , Processed in 0.759391 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
