STM32F427发送,用232转u***接到电脑上,用串口调试助手接收,发送6个字节是{3F,01,03,04,00,校验和},电脑接收的6个字节是{60 7F 7E DF 71 00},求助了。
程序代码如下: void Uart_init(void) { USART_InitTypeDef USART_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //RX GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //TX GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_USART3); GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_USART3); USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx; USART_Init(USART3, &USART_InitStructure); USART_Cmd(USART3, ENABLE); } void Usart3_SendData(USART_TypeDef* USARTx, unsigned char TempData) { while(!(USARTx->SR&0x80)); //while(!(USARTx->SR&0x40)){}; //while(USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET){} USARTx->DR = (TempData & (uint16_t)0x01FF); //while(USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET){} //while((USARTx->SR&0x40)==0); } void usart3_send_data(unsigned char Send_number,unsigned char *Send_data) { unsigned char i; for(i=0;i Usart3_SendData(USART3, Send_data); //delay_ms(2); } } void Sensor_Data_Generate_Send(void) { unsigned char i=0; Data_Buffer[0]=0x3F; Data_Buffer[1]=0x01; Data_Buffer[2]=0x03; Data_Buffer[3]=0x04; for(i=4;i<5;i++) { Data_Buffer=0x00; } CHK_SUM=0; for(i=0;i<5;i++) CHK_SUM+=Data_Buffer; Data_Buffer[5]=CHK_SUM % 255; usart3_send_data(6, Data_Buffer); } |
8个回答
盼回复,多谢了,调试了好久
首先多谢回复。波特率应该没有问题,硬件上看什么呢?
串口这玩意, 调试时端口配置时要普通模式, 复用模式换着试下. 硬件的话就是外部晶振了. 晶振的下地电容, 还是晶振损坏都会影响的
波特率不对,楼主用示波器看一下波特率是多少。还有主频时钟的配置。
我也是401的串口弄不出来,直接用103的移过来也是不行
问题找到了吗?
不错,很好的经验分享,辛苦麻烦了,欠缺这方面的资料,非常感谢。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2961 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2463 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2331 浏览 0 评论
2455 浏览 1 评论
1674 浏览 1 评论
/9
GMT+8, 2025-12-3 02:49 , Processed in 1.148447 second(s), Total 89, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
9788
