电子发烧友论坛|
嗨,我是新手,也是编写必须与Agilent / Keysight设备配合使用的应用程序的新手。
我已经开始基于主站点和论坛上的一些示例编写基本应用程序,但现在我不知道如何进一步移动。 我需要的是一个应用程序,它允许我配置我的设备(34972A与34901A卡)主要用于热电偶测量,开始测量并将它们记录到文件中。 基本配置(设置用于J / K类型TC测量的通道)似乎很容易,但我如何配置它来进行连续测量并将数据发送到我的应用程序。 它可以根据事件(从设备收到的数据)工作吗? 或者我必须“手动”从中读取数据,比方说,每隔一两秒。 还有一件事......哪种编程方式更容易或更好? 我的意思是我应该使用哪种技术。 它是基本的SCPI命令,IVI COM驱动程序,VISA还是其他什么? 现在我正在使用来自Agilent.Agilent34970的类。在IVI Foundation目录中找到的Interterop库。 以上来自于谷歌翻译 以下为原文 Hi I am new here and new to writing applications that have to work with Agilent/Keysight devices. I've started writing basic app based on some examples found on main site and forum, but now i don't know how to move any further. What i need is an app, that lets me configure my device (34972A with 34901A card) mainly for thermocouple measurements, start measurements and log them into a file. Basic configuration (setting channels to measure with TC of type J/K) seems quite easy, but how can i configure it to make continuous measurements and send data to my app. Can it work based on events (data received from device)? or do i have to "manually" read data from it, lets say, every second or two. And one more thing ... which way of programming is easier or better? By that i mean which technology should i use. Is it basic SCPI commands, IVI COM Driver, VISA or something else? Right now i am using classes from Agilent.Agilent34970.Interop library found in IVI Foundation directory. |
2个回答
有一个名为Benchlink Datalogger III的免费软件,可以很好地满足您的需求。
但是如果你想沿着C#路线走下去,请告诉我,我可以帮助你并给你一个简短的例子来帮助你。 http://www.keysight.com/main/software.jspx?cc=US&lc=eng&ckey=778242&nid=-33261.536883644&id=778242 以上来自于谷歌翻译 以下为原文 There is free software called Benchlink Datalogger III which will fit your needs nicely. But if you want to go down the C# route, let me know and I can help and send you a brief example to get you going. http://www.keysight.com/main/software.jspx?cc=US&lc=eng&ckey=778242&nid=-33261.536883644&id=778242 |
4864165sas 发表于 2018-10-31 19:02 嗨〜我目前正在使用34972A而不是C#应用程序。 目的:与34972A通信并获得阅读,然后以BACnet格式发送。 完成:通过USB连接获取数据。 愿望清单:1。使用C#通过LAN(TCP / IP)连接获取数据。 2.重新包装并以BACNet格式发送。 我可以在C#(通过TCP / IP)中获取数据采集的示例代码吗? 十分感谢。 你需要我的电子邮件吗? 再次感谢。 编辑:GenergyZuYao于2014年10月15日8:51 PM编辑:GenergyZuYao于2014年10月15日下午8:52 以上来自于谷歌翻译 以下为原文 Hi~ I'm currently working on 34972A over C# application. Aim: Communicate with 34972A and get reading, then send in BACnet format. Done: Get data over USB connection. Wish list: 1. Get data over LAN (TCP/IP) connection, using C#. 2. Repackage and send in BACNet format. Can I have a sample code of data acquisition in C# (over TCP/IP)? thanks alots. Did you required my email? Thanks again. Edited by: GenergyZuYao on Oct 15, 2014 8:51 PM Edited by: GenergyZuYao on Oct 15, 2014 8:52 PM |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 08:54 , Processed in 0.767121 second(s), Total 95, Slave 78 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1955
