嗨,建议在此PAIN中使用哪些电缆连接到6 Ghz N型端口。我在手册中找不到此信息。
以上来自于谷歌翻译 以下为原文 Hi, what cables are recomended to use in this PNA that goes to 6Ghz N type ports.I could not find this information on the manual. |
6个回答
尝试这个。
1)在Google中键入型号,找到适用于VNA的Keysite网站2)单击文档选项卡。 3)有一个名为“配置指南”的文档,听起来可能有用。 4)下载文档并在Acrobat阅读器中打开。 5)请参阅第4页,其中列出了电缆 - N6314A& N6315A。 由于一个是M-M和其他M-F,你可能想要其中一个。 写这封邮件比找信息花了我更长的时间! 我甚至没有PNA,但我对如何使用计算机有基本的了解。 戴夫 以上来自于谷歌翻译 以下为原文 Try this. 1) Type model number in Google and find the Keysite web site for your VNA 2) Click the documentation tab. 3) There's a document called "Configuration guide", which sounds like it might be useful. 4) Dowload the document and open in Acrobat reader. 5) Look on page 4, where it lists the cables - N6314A & N6315A. Since one is M-M and the othet M-F, you probably want one of each. It took me longer to write this message than it did to find the information! I don't even have a PNA, but I do have a basic understanding of how to use computers. Dave |
60user7 发表于 2018-10-26 16:17 > {quote:title = drkirkby写道:} {quote} >>我写这条消息比找到信息花了更长的时间! 我甚至没有PNA,但我对如何使用计算机有基本的了解。 >谢谢,下次右键单击复制并粘贴到文档的链接。 以上来自于谷歌翻译 以下为原文 > {quote:title=drkirkby wrote:}{quote} > > It took me longer to write this message than it did to find the information! I don't even have a PNA, but I do have a basic understanding of how to use computers. > Thanks, Next time right click copy and paste just the link to the doc. |
ianwhoani 发表于 2018-10-26 16:27 哦,看来drkirkby有一个比我更好的答案。 以上来自于谷歌翻译 以下为原文 Oh, it seems drkirkby has a better answer than me. |
嗨,如果您查看PNA配置指南(文献编号5990-7745EN),您可以看到建议的N型端口电缆:“使用推荐用于7mm连接器和7mm连接器的测试端口电缆 -
来自85054B / D Type-N校准套件的N个适配器(参见7 mm连接器部分)“在大多数实际应用中,我看到人们在PNA的N型端口上连接Type-N到3.5 mm适配器,然后使用 3.5毫米或SMA电缆。 以上来自于谷歌翻译 以下为原文 Hi, if you take a look at the PNA configuration guide (literature no 5990-7745EN), you can see the recommended cables for type-N ports: "Use the test port cables recommended for devices with 7mm connectors, and 7mm to Type-N adapters that are from the 85054B/D Type-N calibration kit (see 7 mm connector section)" In most real applications, I see people attach Type-N to 3.5 mm adapters on the Type-N ports of the PNA, then use 3.5 mm or SMA cables. |
平凡的世界12 发表于 2018-10-26 16:52 > {quote:title = ningchen写道:} {quote} >>在大多数实际应用中,我看到人们在PNA的Type-N端口上连接Type-N到3.5 mm适配器,然后使用3.5 mm或SMA电缆。 使用N型到3.5毫米电缆而不是使用适配器不是更好吗? 以上来自于谷歌翻译 以下为原文 > {quote:title=ningchen wrote:}{quote} > > In most real applications, I see people attach Type-N to 3.5 mm adapters on the Type-N ports of the PNA, then use 3.5 mm or SMA cables. Wouldn´t it be better to use N type to 3.5 mm cables instead of using adapters? |
ianwhoani 发表于 2018-10-26 17:09 是的,抱歉这个混乱。 如果你的DUT有N型连接器,最方便的电缆是N型到N型连接器; 如果您的DUT具有3.5 mm连接器,则可以选择N型至3.5 mm电缆或3.5 mm电缆。 3.5毫米电缆更常见,因此我看到使用3.5毫米电缆的更多应用。 以上来自于谷歌翻译 以下为原文 Yes, sorry for the confusion. If your DUT has Type-N connectors, the most convenient cables are with Type-N to Type-N connectors; if your DUT has 3.5 mm connectors, Type-N to 3.5 mm cable or 3.5 mm cables are up to your choice. 3.5 mm cables are more common so I see more applications using 3.5 mm cables. |
只有小组成员才能发言,加入小组>>
1072 浏览 0 评论
2307 浏览 1 评论
2094 浏览 1 评论
1968 浏览 5 评论
2839 浏览 3 评论
842浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
616浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
716浏览 0评论
1400浏览 0评论
1074浏览 0评论
GMT+8, 2024-10-1 20:51 , Processed in 1.471944 second(s), Total 88, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
