您好朋友,我已经使用8514B测试装置将HP8516A opt001 40Ghz参数测试装置集成到我的8510C配置中。
为此,在GPIB和同轴电缆中有两根电缆连接到8516A:1)测试装置互连电缆参考号08516-60102,我已经有了这个,当然是最难获得的。 2)RS232电缆组件参考号08516-60009,我需要这个。 它是两侧的DB25电缆,我猜没什么难的。 有人可以给我这个电缆的图纸,以确定我如何建立它? 该电缆将8516A的“源控制”端口连接到83621B清扫器的源控制端口输出。 这肯定是为了驱动8516A内部的倍增器。 非常感谢您的帮助。 最好的问候Pierre-Francois,F5BQP 以上来自于谷歌翻译 以下为原文 Hello Friends, I've to integrate a HP8516A opt001 40Ghz parameter test set into my 8510C configuration using already a 8514B test set. To do so there are two cables to attach to the 8516A among GPIB and coax cables: 1) A Test Set Interconnect cable reference 08516-60102 , I already have this one, certainly the hardest to get. 2) A RS232 cable assembly reference 08516-60009, I need this one. It's a DB25 cable both sides, nothing difficult to build I guess. Can someone give me the drawing of this cable to be sure how I have to build it? This cable connects the "Source Control" port from the 8516A to the source control port output from the 83621B sweeper. This is certainly to drive the doubler which is inside the 8516A. Many thanks in advance for your help. Best regards Pierre-Francois, F5BQP |
1个回答
嗨,我没有得到这个组的回复,但我已经在83621B和8516A之间测试了RS232 DB25(m)到DB25(m)电缆,它工作正常。
Pierre-Francois,F5BQP 以上来自于谷歌翻译 以下为原文 Hi, I got no response from this group, however I've tested a RS232 DB25 (m) to DB25(m) cable between the 83621B and the 8516A and it works fine. Pierre-Francois, F5BQP |
只有小组成员才能发言,加入小组>>
1298 浏览 0 评论
2378 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1141浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
760浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
950浏览 0评论
1299浏览 0评论
GMT+8, 2024-12-29 05:15 , Processed in 1.667989 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
