我看了但是找不到这个MCU的操作码的完整列表。我正在使用STM8S-Discovery来教我的孩子编程,从最基本的机器语言开始,然后是汇编程序,然后是C.我希望它们能够读取由高级语言生成的代码。我发现程序员手册中列出了大约80个代码,但这不是整套代码。有没有人知道是否已经发布了一整套,或者如果我创建了一整套就会有人反对。
以上来自于谷歌翻译 以下为原文 I have looked but can't find a ''complete listing of the op-codes for this MCU. I'm using the STM8S-Discovery to teach my grand-kids programming, starting at the very basic machine language, then to assembler and then C. I want them to be able to read the code that is generated by the high level language. I found about 80 codes listed in the programers manual, but that is not the entire set. Does anyone know if a full set has been published, or if anybody would object if I created one. |
2个回答
我不知道这里的外围设备手册是stm8s的cpu手册
http://www.st.com/web/en/resource/technical/document/programming_manual/CD00161709.pdf 但似乎不包含写入模数转换器dac或uart或gpio的指令。我正在建立一个反汇编程序。我需要在sourceforge上发布它。我得到它来识别所有的CPU指令。但我找不到perifferal访问指令 以上来自于谷歌翻译 以下为原文 i don't know where a manual for the peripherals here is the cpu manual for the stm8s http://www.st.com/web/en/resource/technical/document/programming_manual/CD00161709.pdf but it appears that that does not contain the instructions for writing to the analog to digital converter dac or uart or gpio . i am building a disassembler. i need to publish it on sourceforge. i got it to recognise all the cpu instructions. but i can't find the perifferal access instructions |
所有I / O都在STM8中进行内存映射。一个简单的ld(x),a可以根据x的值进行I / O.
菲利普 以上来自于谷歌翻译 以下为原文 All I/O is memory mapped in the STM8. A simple ld (x), a can do I/O depending on the value of x. Philipp |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1960 浏览 1 评论
2681 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1558 浏览 1 评论
3121 浏览 6 评论
5557 浏览 21 评论
533浏览 4评论
945浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
349浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
913浏览 3评论
869浏览 3评论
GMT+8, 2024-6-26 22:48 , Processed in 0.898436 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
