电子发烧友论坛|
嗨,
今天我有一个非常特别的问题: 我在编程手册中读到,DIV和DIVW的指令是可中断的。 当计算处于活动状态时发生中断时会发生什么 - 使用寄存器(A,X,Y)和 - 如何在IRET后继续计算??? 谁能回答? tiA, WoRo #divw #div 以上来自于谷歌翻译 以下为原文 Hi, today I have a very special question: I read in the programming manual, that the instructions DIV an DIVW are interruptible. What exactly happens, when an interrupt occurs while calculating is active - with the registers (A, X, Y) and - how does calculating continue after IRET??? Who can answer? TIA, WoRo #divw #div |
2个回答
你好WoRo!
我不知道STM8核如何实现DIV / DIVW指令。 STM8勘误表文档提供了一些见解,因为在ISR中始终存在“意外的DIV / DIVW指令”子部分。 当中断执行DIV / DIVW指令而另一个事件中断IRET指令时,会发生此错误。 似乎未使用的CC位在DIV / DIVW执行中起一定作用。 在我看来,专用硬件单元处理DIV / DIVW指令,当其结果准备好时,所涉及的寄存器被更新。这些更新可能由这些未使用的位之一(通常为空)强制执行,但只有STM8核心设计人员才知道会发生什么。 我认为ISR应该避免这些指令,但它可能过于保守...... EtaPhi 以上来自于谷歌翻译 以下为原文 Hello WoRo! I don't know how STM8 core implements DIV/DIVW instructions. STM8 errata documents provide some insight, as there is always an ''Unexpected DIV/DIVW instruction in ISR'' sub-section. This error happens when an interrupt executes a DIV/DIVW instruction and another event interrupts the IRET instruction. It seems that unused CC bits play some role in DIV/DIVW execution. In my opinion, a dedicated hardware unit processes DIV/DIVW instructions and when its result is ready, the involved registers are updated. This update may be forced by one of these unused bits (which are usually null), but only the STM8 core designers know what happens. I think that ISRs should avoid these instructions, but it may be too much conservative... EtaPhi |
我通过模拟中断堆栈帧尝试运行IRET指令失败了。
无论要恢复的CC值是什么,输出都是相同的:没有意外的X或Y寄存器值。 CC的第6位(未定义)似乎对IRET执行没有影响。 出于这个原因,我认为DIV / DIVW指令使用影子寄存器,用户代码无法访问,以及对用户也隐藏的触发器。 对不起,您的问题似乎没有答案。 问候, EtaPhi 以上来自于谷歌翻译 以下为原文 I unsuccessfully tried to exercise IRET instruction by simulating an interrupt stack frame. Whatever the CC value to restore is, the output is the same: no unexpected X or Y register value. It seems that bit 6 of CC, which is undefined, has no effect on IRET execution. For this reason, I suppose that DIV/DIVW instructions use shadow registers, which user code can't access, and a flip/flop which is hidden to the user too. Sorry, it seems that there is no answer to your question. Regards, EtaPhi |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 21:48 , Processed in 1.789676 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
428
