用STM32L052采样AD,两个通道,其中一个通道要用过采样技术,通道的切换是在AD中断进行。请问是否每次都要校准HAL_ADCEx_Calibration_Start()?而每次AD中断中,参数设置的时候,是否都要关中断HAL_ADC_Stop_IT() ,参数设置完在开中断HAL_ADC_Start_IT()?
/* ADC2 init function */ void MX_ADC2_Init(void) { ADC_ChannelConfTypeDef sConfig; /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion) */ hadc.Instance = ADC1; hadc.Init.OversamplingMode = DISABLE; hadc.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV1; hadc.Init.Resolution = ADC_RESOLUTION12b; hadc.Init.SamplingTime = ADC_SAMPLETIME_7CYCLES_5; hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD; hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc.Init.ContinuousConvMode = DISABLE; hadc.Init.DiscontinuousConvMode = ENABLE; hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIG_EDGE_NONE; hadc.Init.DMAContinuousRequests = DISABLE; hadc.Init.EOCSelection = EOC_SINGLE_CONV; hadc.Init.Overrun = OVR_DATA_PRESERVED; hadc.Init.LowPowerAutoWait = DISABLE; hadc.Init.LowPowerFrequencyMode = ENABLE; hadc.Init.LowPowerAutoPowerOff = DISABLE; HAL_ADC_Init(&hadc); /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_2; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; HAL_ADC_ConfigChannel(&hadc, &sConfig); } /* ADC7 init function */ void MX_ADC7_Init(void) { ADC_ChannelConfTypeDef sConfig; /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion) */ hadc.Instance = ADC1; hadc.Init.OversamplingMode = ENABLE; hadc.Init.Oversample.Ratio = ADC_OVERSAMPLING_RATIO_128; hadc.Init.Oversample.RightBitShift = ADC_RIGHTBITSHIFT_3; hadc.Init.Oversample.TriggeredMode = ADC_TRIGGEREDMODE_SINGLE_TRIGGER; hadc.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV1; hadc.Init.Resolution = ADC_RESOLUTION12b; hadc.Init.SamplingTime = ADC_SAMPLETIME_7CYCLES_5; hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD; hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc.Init.ContinuousConvMode = DISABLE; hadc.Init.DiscontinuousConvMode = ENABLE; hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIG_EDGE_NONE; hadc.Init.DMAContinuousRequests = DISABLE; hadc.Init.EOCSelection = EOC_SINGLE_CONV; hadc.Init.Overrun = OVR_DATA_PRESERVED; hadc.Init.LowPowerAutoWait = DISABLE; hadc.Init.LowPowerFrequencyMode = ENABLE; hadc.Init.LowPowerAutoPowerOff = DISABLE; HAL_ADC_Init(&hadc); /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_7; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; HAL_ADC_ConfigChannel(&hadc, &sConfig); } |
6个回答
设置 的时候必须关掉中断 设置完成才开启中断。 运行ad转换 现在是通道7,可以切到通道2 但通道2,切不到通道7 |
uint8_t CH_dp=0;
/* ADC init function */ void MX_ADC_Init(void) { ADC_ChannelConfTypeDef sConfig; hadc.Instance = ADC1; hadc.Init.OversamplingMode = ENABLE; hadc.Init.Oversample.Ratio = ADC_OVERSAMPLING_RATIO_128; hadc.Init.Oversample.RightBitShift = ADC_RIGHTBITSHIFT_3; hadc.Init.Oversample.TriggeredMode = ADC_TRIGGEREDMODE_SINGLE_TRIGGER; hadc.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV1; hadc.Init.Resolution = ADC_RESOLUTION12b; hadc.Init.SamplingTime = ADC_SAMPLETIME_7CYCLES_5; hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD; hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc.Init.ContinuousConvMode = ENABLE; hadc.Init.DiscontinuousConvMode = DISABLE; hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIG_EDGE_NONE; hadc.Init.DMAContinuousRequests = DISABLE; hadc.Init.EOCSelection = EOC_SINGLE_CONV; hadc.Init.Overrun = OVR_DATA_PRESERVED; hadc.Init.LowPowerAutoWait = DISABLE; hadc.Init.LowPowerFrequencyMode = ENABLE; hadc.Init.LowPowerAutoPowerOff = DISABLE; HAL_ADC_Init(&hadc); /* USER CODE BEGIN 7 */ if (HAL_ADCEx_Calibration_Start(&hadc, ADC_SINGLE_ENDED) != HAL_OK) { Error_Handler(); } /* USER CODE END 7 */ /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_7; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; HAL_ADC_ConfigChannel(&hadc, &sConfig); } /* ADC2 init function */ void MX_ADC2_Init(void) { ADC_ChannelConfTypeDef sConfig; hadc.Instance = ADC1; hadc.Init.OversamplingMode = ENABLE; hadc.Init.Oversample.Ratio = ADC_OVERSAMPLING_RATIO_128; hadc.Init.Oversample.RightBitShift = ADC_RIGHTBITSHIFT_3; hadc.Init.Oversample.TriggeredMode = ADC_TRIGGEREDMODE_SINGLE_TRIGGER; hadc.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV1; hadc.Init.Resolution = ADC_RESOLUTION12b; hadc.Init.SamplingTime = ADC_SAMPLETIME_7CYCLES_5; hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;//轮流对各个通道进行采集 hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;//数据对齐方式 hadc.Init.ContinuousConvMode = ENABLE;//连续转换模式 hadc.Init.DiscontinuousConvMode = DISABLE; hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIG_EDGE_NONE;//控制触发模式 hadc.Init.DMAContinuousRequests = DISABLE; hadc.Init.EOCSelection = EOC_SINGLE_CONV; hadc.Init.Overrun = OVR_DATA_PRESERVED; hadc.Init.LowPowerAutoWait = DISABLE; hadc.Init.LowPowerFrequencyMode = ENABLE; hadc.Init.LowPowerAutoPowerOff = DISABLE; HAL_ADC_Init(&hadc); /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_2; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; HAL_ADC_ConfigChannel(&hadc, &sConfig); } /* ADC7 init function */ void MX_ADC7_Init(void) { ADC_ChannelConfTypeDef sConfig; hadc.Instance = ADC1; hadc.Init.OversamplingMode = ENABLE; hadc.Init.Oversample.Ratio = ADC_OVERSAMPLING_RATIO_128; hadc.Init.Oversample.RightBitShift = ADC_RIGHTBITSHIFT_3; hadc.Init.Oversample.TriggeredMode = ADC_TRIGGEREDMODE_SINGLE_TRIGGER; hadc.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV1; hadc.Init.Resolution = ADC_RESOLUTION12b; hadc.Init.SamplingTime = ADC_SAMPLETIME_7CYCLES_5; hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD; hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc.Init.ContinuousConvMode = ENABLE; hadc.Init.DiscontinuousConvMode = DISABLE; hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIG_EDGE_NONE; hadc.Init.DMAContinuousRequests = DISABLE; hadc.Init.EOCSelection = EOC_SINGLE_CONV; hadc.Init.Overrun = OVR_DATA_PRESERVED; hadc.Init.LowPowerAutoWait = DISABLE; hadc.Init.LowPowerFrequencyMode = ENABLE; hadc.Init.LowPowerAutoPowerOff = DISABLE; HAL_ADC_Init(&hadc); /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_7; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; HAL_ADC_ConfigChannel(&hadc, &sConfig); } void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* AdcHandle) { /* Get the converted value of regular channel */ uwADCxConvertedValue = HAL_ADC_GetValue(AdcHandle); HAL_ADC_Stop_IT(&hadc); if(CH_dp==0) { CH_dp=1; MX_ADC2_Init(); } else { CH_dp=0; MX_ADC7_Init(); } HAL_ADC_Start_IT(&hadc); HAL_UART_Transmit_IT(&huart1, (uint8_t*)uwADCxConvertedValue, 4); } void HAL_UART_TxCpltCallback(UART_HandleTypeDef *UartHandle) { } int main(void) { /* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /* MCU Configuration----------------------------------------------------------*/ /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* Configure the system clock */ SystemClock_Config(); /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_ADC_Init(); MX_COMP1_Init(); MX_TIM21_Init(); MX_USART1_UART_Init(); /* USER CODE BEGIN 2 */ HAL_COMP_Start(&hcomp1); HAL_ADC_Start_IT(&hadc); /* USER CODE END 2 */ /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { /* USER CODE END WHILE */ /* USER CODE BEGIN 3 */ } /* USER CODE END 3 */ } |
感谢,安大师的例程。。
可以了 void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* AdcHandle) { /* Get the converted value of regular channel */ uwADCxConvertedValue = HAL_ADC_GetValue(AdcHandle); HAL_ADC_Stop_IT(&hadc); if(CH_dp==0) { CH_dp=1; ADC1->CHSELR = ADC_CHANNEL_2; } else { CH_dp=0; ADC1->CHSELR = ADC_CHANNEL_7; } HAL_ADC_Start_IT(&hadc); HAL_UART_Transmit_IT(&huart1, (uint8_t*)uwADCxConvertedValue, 4); } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1328 浏览 1 评论
1070 浏览 0 评论
936 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
5174 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
3974 浏览 1 评论
/9
GMT+8, 2025-12-14 08:34 , Processed in 1.708457 second(s), Total 52, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
556
