电子发烧友论坛|
我有一个设计花了大约4-5个小时来完成vivado 2013.2的综合和实现。
我做了一些小的改动,现在我被困在第3.4阶段提交小宏和& 核心逻辑超过24小时。 我重新运行了我的脚本两次,它一直卡在这里。 任何想法为何陷入困境? 以上来自于谷歌翻译 以下为原文 I had a design that took about 4-5 hours to get through synthesis and implementation with vivado 2013.2. I made some minor changes and now i have been stuck in Phase 3.4 Commit small Macros & Core Logic for over 24 hours. I have re ran my script twice and it keeps getting stuck here. Any ideas why its getting stuck? |
8个回答
你能试试2013.3吗?
它可能会有所帮助或提供更好的错误。 以上来自于谷歌翻译 以下为原文 Can you try in 2013.3? It might help or give a better error. |
我和2013.3 vivado一样。
但是,我认为这可能与区域约束(pblocks)有关,因为这是我在问题发生之前所做的事情。 我运行了一个工作正常的放置器,我正在更糟糕的区域,运行report_timing_summary来建立下一个错误,然后添加更多约束。 我只有几个去,然后gui锁定。 此时构建已陷入困境,因此我将不得不删除pblock并重新开始。 也许vivado可以支持最大数量的pblock。 令人沮丧。 以上来自于谷歌翻译 以下为原文 I am getting the same, and with the 2013.3 vivado. However, I am thinking that this is probably related to area constraints(pblocks), as this is what i was doing before the issue. I had run the placer which worked fine and I was pblocking the worse areas, running the report_timing_summary to establish the next error, and then adding more constraints. i only had a few more to go and then the gui locked up. Builds have got stuck at this point since so I am going to have to remove the pblocks and start again. Perhaps there is a maximum number of pblocks that vivado can support. Its frustating. |
pblocks太小了吗?
使用较小尺寸的plocks处理时存在一个错误。(放置器宽度为1的panthandle pblocks)。 你能看看吗? 以上来自于谷歌翻译 以下为原文 Are the pblocks too small? There was a bug for handling with smaller size plocks.(placer cant handle pblocks with width of 1). Can you check this? |
我有DSP48_X17Y194:DSP48_X17Y195(加上其他),宽度为1,但如果你的意思是SLICE,RAMB18或RAMB36,那么没有。
以上来自于谷歌翻译 以下为原文 I have DSP48_X17Y194:DSP48_X17Y195 (plus others) which is a width of 1, but if you mean either the SLICE, RAMB18 or RAMB36, then no. |
限制也适用于DSP / BRAM。
这是在2014.1修复。 你可以尝试增加该pblock的宽度吗? 以上来自于谷歌翻译 以下为原文 The limitation is for DSP/BRAM as well. This is fixed in 2014.1. Can you try by increasing the width for that pblock? |
我会评论那些特定的pblock,看看是不是,但我肯定会下载最新的vivado。
我不确定我们现在是否可以增加尺寸,直到我可以在gui中查看,但由于计划是做一些较小的,我不确定那是不是现在的方式。 以上来自于谷歌翻译 以下为原文 I'll comment out those particular pblocks and see if it is that, but I i wlll certainly download the latest vivado as well. I'm not sure if we can increase the size at the moment until I can view in the gui, but since the plan was to do some smaller ones, I'm not sure that that is the way to go as yet. |
有一个补丁可用于2013.4修复与宽度为1的pblock相关的错误。如果你想要补丁你可以打开一个webcase并要求补丁到CR 762357。
以上来自于谷歌翻译 以下为原文 There is a patch available for 2013.4 to fix the bug related to pblocks with width of 1. If you want the patch you can open a webcase and ask for the patch to CR 762357. |
@sembarc_xil请告诉我你的结果。
以上来自于谷歌翻译 以下为原文 @sembarc_xil Please keep me posted with your results. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 10:07 , Processed in 3.586458 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
405
